A Few Unusual Questions — Looking for Some Advice ! :)
  • A Few Unusual Questions — Looking for Some Advice ! :)
    Hi everyone at Geotech!
    I'm currently working on a personal project that combines a metal detector with an RC vehicle. I've run into a few technical challenges along the way, and I'm hoping to get some advice or ideas from the community.
    Shielding and Interference Issues
    This has been a bit of a tricky problem for me.
    The search coil is mounted underneath the vehicle, but there are motors, sensors, and other electronic components nearby that can interfere with it.
    Ideally, I'd like the coil to be mainly sensitive to what's underneath it (toward the ground), while minimizing interference coming from the sides and above.
    I've been looking into shielding materials for VLF metal detectors, particularly mu-metal (permalloy). However, when I bought some and placed it near the coil, the shielding material itself seemed to interfere with the detector's performance. That left me a little confused.
    I also tried moving all the electronic components further away from the coil, and that actually worked pretty well. Unfortunately, it made the vehicle much larger than I'd like.
    To keep the vehicle compact and easy to transport, I'm trying to​ fit everything within 600 mm × 500 mm.
    For reference, I'm currently using a 9.8-inch search coil.
    Has anyone here dealt with a similar issue? I'd really appreciate any suggestions on shielding techniques, materials, or coil placement that might help reduce interference without making the vehicle too large.
    Thanks in advance for any advice!
    There's too much metal visible in the pictures. The yellow supports are definitely metal, as is the white plate in front of the front axle. I'd replace those with non-metallic material first. Then, get rid of the LED strips for now. What kind of detector electronics are you using in your project? Any well-known circuits?
      Hi, Guru.
      Thank you for reply.
      Sorry that I forgot to explain some of the vehicle's components.
      The yellow parts are made of fiberglass. Although fiberglass is slightly heavier than carbon fiber, it's much more affordable and doesn't interfere with the metal detector.
      The white section you mentioned is actually the rear of the vehicle. The vehicle uses a front-wheel-drive system, with power delivered to both front wheels.
      The black and white parts you see are currently 3D-printed using carbon-filled materials. The front and rear wheels are the only components that contain metal.
      I've already ordered some wheels with plastic rims and tires without steel reinforcement. These should help further reduce interference with the metal detector.
      As for the search coil, I'm currently using one from an unknown brand, while the circuit board is something I designed and built myself.
        The real question is .....what sort of targets, ground and depth are you working with.
          An induction-balanced system of the coaxial type (Rx-Tx-Rx) is the least sensitive possible to interference and targets located to the sides of the coils.
            1. Move the coil closer to the rear wheels; looks like there is room for that.
            2. Get rid of the LEDs; pulsed LED currents cause interference, I run into that all the time with walk-thru designs.
            3. Lengthen the chassis; make the yellow frame rails telescopic if the goal is to fit the whole thing in a hatchback. Extend it on-site.
            4. Permalloy is the wrong stuff to use near the coil, possibly it is saturating and looking like iron. Try a ferrite sheet instead, although they are generally not good enough to block strong near signals. You can try multiple layers but this can cause a reactive overload in the detector.
            5. Design a fully shielded coil. You can design a coil with, say, a large shielding plate on one side but you have to set the IB windings with the shield in place to make it work. What you are trying to do right now is add heavy shielding to a coil that was not designed for it.
            6. Enclose all the control circuitry in a heavily shielded box that is not close enough to the coil that the shielding itself is detected.
            7. This still leaves wiring to e.g. stepper motors which have high current pulses; do those with twisted pairs or twisted quad (like star-quad).
            8. Where are the stepper motors that drive the wheels? Depending on their locations, there may be something to do there since their windings will be a dominant noise source.
              Hey Carl.
              1. Yeah, the coil will be move to the rear wheel for a bit, like 2cm.
              2. And the LED will be removed.
              3. But,the chassis i will perfer in a fixed lenthen, fiberglass will change into plastic once i solve the issues from the detection module.
              4. I've also tried using ferrite sheets as shielding material. However, whenever I placed them near the search coil, the detector started beeping erratically, producing all kinds of different signals.
              Do you think I should try different types of ferrite sheets, or could there be something wrong with the detector circuit we've developed?
              Also, i would like to start a second thread on the forum to share our current detector circuit schematic and ask the community for suggestions on how to improve it.
              5. "What you are trying to do right now is add heavy shielding to a coil that was not designed for it." you are right , in "large shield" i would like to know more! how?
              6. is the box in ferrite sheets as well?
              7. i have left a safe dicstan between the stepper motors and coil about (15cm). and they are working okay when i take the vehicle out for a test. The tests include navigating over rocks and obstacles up to 10 cm high, crossing tree roots,
              and evaluating the vehicle's ability to handle getting stuck in sand. The out comes is the chassis working fine, but the MD module produce fake signle while the vehicle bouncing. HAHAHA i'm using twisted quad so far. is star-quad better? never heared of it.
              8. the front wheels itself is a stepper motor. about (15cm) from the sides of the coil.
                Do you use separate batteries for the motors and the electronics? I suggest placing the motor power batteries inside a metal enclosure and using shielded cables for the motor wiring; most interference is picked up by the search coil. To locate the source of the interference, you can use a small AM radio—hold it close to the motors, then near the wires. You can also use metal boxes for the electronics; for reference, take a look at the housing of a car radio.Click image for larger version
                = placing metals near the coil requires adjusting the coil's balance, metal structural components may be used, but they must be very stable in their positioning relative to the coil.
                Click image for larger version  Name:	image.png Views:	0 Size:	41.9 KB ID:	454411​
                a lot of metal near the coils
                  hey,Pito.
                  the batteries are in two pices, so far, all components are sharing one battery system. should i separate the system into two? The search coil is currently fixed relative to the vehicle chassis, with no movement between them. I've been thinking to use gimbal to connect the coil and chassis but it will cost more
                  interference.
