MCD-5000B metal detector from Shenzhen MCD Electrónica CO.
  • MCD-5000B metal detector from Shenzhen MCD Electrónica CO.
ID:	455084 Click image for larger version
ID:	455085 Click image for larger version
ID:	455082 Click image for larger version
    Hello friends, I bought this metal detector. The seller was originally only offering the search coil for $45, but offered to sell me the entire unit for $60, so I bought the whole thing. I couldn't turn the detector on because the power cable was missing; I made one myself and managed to power it up, but there is no sound output. I had to connect an external speaker since it didn't come with headphones. Looking into the audio section, I discovered that the LM386 IC isn't receiving any power. Tracing the circuit paths, I found that the power supply is controlled by an STM32 F103 microcontroller. Furthermore, upon opening the detector's housing, I found a 5-wire cable with two of the wires severed. I also noticed that the "Search Mode" selector switch has no wires soldered to it. Additionally, some of the PCB connectors were incorrectly installed: two 2-pin connectors were plugged into a 5-pin socket, and a 3-pin connector was plugged into a 4-pin socket. It’s clear that someone has been tampering with the wiring. Could you please help me by providing photographs or a schematic for this detector so I can figure out the correct wiring connections?
      Based on the assessment of the quality of the glue that is glued switches; I'm almost sure it's genuine Minelab!
      Lucky man!​
      "...It’s clear that someone has been tampering with the wiring..."
      It is not necessary...
      I remember that x years ago someone also opened the Chinese "Minelab" and found that half of the "commands" on the panels were not connected to the pcb...
      because there were no points where they should be connected.
      It all depends on which "cat in the sack" you got, the Chinese produce them in various variants!
      Now... that's what I call a real adventure!
      Bigger than the reverse engineered XP Deus 2!
      I envy you!
        Given that you at least have an identical enclosure; I suggest the following!
        I have personally posted the complete documentation for the DIY Minelab Relic Hawk on the forum several times.
        Because that model also uses the same enclosure, so both the main pcb and the panel pcb will fit perfectly.
        Throw that Chinese junk out of the enclosure and make yourself a DIY Relic Hawk, you won't regret it!
        If you can't find the archive on the forum, let me know, I'll send it to you.
          Thank you very much, Ivconic, for your suggestion.
          Please send me your file.​
            Sure.
            Here it is;
