Miner-2
    Originally posted by Shahab View Post
    Hi Michal.
    Excuse me.I checked my mailbox.Thanks for your answer.
    I'm building Miner-2.If you find any information about it please help me.
    Ok.
    I'm building Miner-4, it is same then Miner-2 only display is 20x4 character.
    If i have new information i send post to you.
    B.R. Michal
      Hi Michal
      Did you finish Miner-4?
        Hi Michal
        Hi, today finishing with "hardware" - case,shaft......
        electronic is finish. If i time testing Miner-4 evening in wood and
        post result.
        B.R. Michal
          Hi Michal
          What did you do with Miner-4?
          If it is OK I repeat that please write about:
          1.Deep of miner-4?
          2.Calibrating & tuning of this circuit?
          3.Difference between metals?
          4.Everything you think
          Good luck.
            hi
            in this site :
            hex file is original version or demo version ?
              Originally posted by sisco View Post
              hi
              in this site :
              Hi, hex for Miner is full version
              Michal
                Hi Michal
                1.Deep of miner-4?
                Good luck.
                my answers:
                1. 1euro coin max. 32cm as iron and 28-29cm as non-iron (color)
                2. I replace AD8055 and TL081 with MAX410 - more stability and more deep
                3. ok, only BIG iron sometimes as color (non-iron)
                4. no need any changes, only value R5 is need change according to coil
                BR
                Michal
                  Very thanks Michal.
                  Please write about max deep of Miner-4?
                  I couldn't find somethings : HCPL3120 , ADS7816 , DAC7611 , TEL2-2421 ,
                  TEL3-2011.Suggest me to use other things ,please.
                  Best wishes.
                    Very thanks Michal.
                    Best wishes.
                    Please write about max deep of Miner-4? - I don´t know cca 1m horseshoe
                    HCPL3120 - i use HPCL3120 www.gme.cz
                    ADS7816 - I use ADS7816 can be MCP3201
                    DAC7611 - I use DAC7611 - i can´t find equivalent, maybe any MAX of MAXIM-ic
                    TEL - I use three pieces PT4243A PT4243C PT4243N as Free Sample from TI
                    More: no need use small coil. Without small c. is same with small c. (reaction of small object)
                    Most need keep resistance of coil between 2 and 2.5Ohms. My coil is 2.1Ohm
                    B.R.
                    Michal
                    P.S. Yesterday i tested Miner with simly big coil (dia. cca 1m) and detect shovel at distance cca 2m
                      hi all
                      can somebody help me for make this converter :
                      I have make inductance meter and need to this converter
                      something like buffer but with convert AC to DC
                        سلام
                        من دنبال یه فلز یاب قوی میگشتم ومیگردم دراین رابطه من مدار پالس 2 گری را ساختم که ای سی7660 ان میسوزد حال از شما کمک میخاهم هم در مورد مدار هم اگه مداره قویی دارید از من دریغ نکنید
                          i need pcb/ part list/shemetic/ metal detector deepers
                            Miner-4
                            Hi guys,
                            I've made Miner-4. Its disc dosn't work properly... Only disc-1 works OK which is not good for me. In that setting only the pure golds can be detected. If the gold be alloyed then it will be showed as FE.
                            ms.nomi,
                            Does your Miner work proper at the disc settings 2, 3, 4 and 5?
                            Best regards,
                            1843
                              Originally posted by mohsen65 View Post
                              سلام
                              سلام محسن
                              اين سايت مدارات خوبي دارد كه من با دوستانم چندتايي از انها را ساختيم بد نبودند ولي قبل از ان بهتر مشخصات دستگاه مورد نظرت را بدوني اما دستگاهي كه ساخته اي دستگاه خوبي نيست وخيلي ضعيف كار ميكنه و مهمتر اينكه تفكيك نداره
                                hello
                                any body here pcb and file the program for miner complete here ??
