Originally posted by chemelec
View Post
1. the values you posted in your revised schematics (also found in french revised schematic and there indicated as yours) : the ones goodrat mailed to you after measuring caps out of the circuit
2. I don't know for sure but think so cause I get better response and disc with these values and diagrams than with original cap values from Carl's schematic
Example: with first set (Carl's) I get problems with iron disc...completely out of phase ...with second set (goodrat's) I get a near-to-complete iron disc for every position of disc pot. Sound just when an iron mass is really near center of coil...means that some strong perturbation of field lines can affect disc capability. Sounds with brick but less than with first set.
A little problem is now around geb ...where I can't get zero as indicated by Qiaozhi but I have same diagram of Goodrat and I can null nearing ferrite sticks...that's indicates geb seems working now. With first set I can't completely tune out ferrite sticks at different distancies.
Of curse is not the "smocking gun" evidence that everything is right (like in original-bought bandidos) in my homemade ...but I think now it's nearer to a bought one.
So I think you are right when say that you think these (goodrat's) are correct values.
Best regards,
about performance". And who has special performance ???? All are "about the same
". There are very litle models that have 20....30% better performance.
