First op-amp...
  • First op-amp...
    Hi all,
    Why in some PIs, the pin3 of their first op-amp is fasten to the gnd by a resistor( generally 1k )?????
    I cut the track of IC6 pin3 in my HH and then added an 1k resistor between that pin and gnd. I didn't see any effect on my HH...!? If I remember good, the op-amp output became out of saturation a little bit.
    Best regards
    When designing for low offset, you normally want to load both inputs in the same way. So if the inverting side has a 1k input resistor, put a 1k on the non-inv side. For the PI preamp, it has almost no effect.
      Ok, Thanks!
