PD3200 Source Code!
  • PD3200 Source Code!
    Hi everybody,
    Here is the PD3200(Demo version) source code. I know somone can add discrimination code to this file and make an original PD3200 code!
    Bugwhiskers should be able to do this job!
    Enjoy ,
    1843
    That isn't source code, it's dis-assembled object code. Sometimes even the best dis-assemblers can't distinguish between op codes and data so even if this code was re-assmbled it may not work.
    I am very sorry but I don't have time to help with this project, too many other projects on the stove.
    bugwhiskers
      Hi bugwhiskers
      Please say me, what is name of the best disasm. Software for avr ?
      Regards .
        IDA Pro
          …but in all honesty it is often easier to just write the code from scratch when the schematic is available.
            Hi Unregistered
            What is your opinion about avrstudio from atmel?
              I have never used an AVR dis-assembler so cannot recommend anything. Google "avr freaks", there are lot's of knowldegable people there.
              bugwhiskers
                Hi bugwhiskers
                Thanks for you guide ,I am also member of avr freaks .
                For disassembling avr m.con. hex file , I am using avr studio 4
                From atmel.
                Best Regards.
                  pd3200 COIL is ohm=?????????
                  coil ohm = ???
                    PD3200
                    PD3200 COIL R=0.5ohm......0.6 ohm
                    INDUCT. 300mikrohenrs.........400mikrohenrs
