Is DSP useful?
  • All is True
    Everything you say is true.
    Though even 20 years ago there were better parts
    that could have been used, and performance can and
    could have been improved by the use of them.
    Quality capacitors in the signal path is a simple example
    but even better analog switches and op amps were all
    there. Cost, multiple sources {and if you do this for real
    you will find this very important}, end up driving the
    selection. The fact that there are probably more
    microprocessors that have come and gone, mainly for the
    reasons you guys state, lower power, more gates, etc.,
    but having to incure the Non-Recurring Engineering costs
    that keep re-accurring because of parts changes, the
    documentation of all the changes, etc. can mean you better
    be moving alot of detectors in those two years or there
    will be very little profit.
    Yea I know, I don't like it either, I want to use the latest
    and greatest as well, who doesn't? but get in a
    electronic manufacturing plant and you will find all sorts
    of fun things happen. Like some companies forbid the use
    of a old cheap can get forever 555 timer. Why?
    Because there are so many variations of the part and it is
    not the same part, you guys know about this, and what
    happens is that sooner or later your parts buyer gets told
    by some ignorant parts salesman that this part is the same
    as that part because his parts sells computer says so.
    And he buys it, or it is cheaper than the last ones he
    bought so he thinks he is doing something smart, even
    though he was warned over and over to only buy say
    LM555 marked National. Or the cmos version which he
    was told is a better substitute and is now ready to
    argue with the engineers because now he KNOWS.
    Even though stuff is not working, and orders are late,
    and you don't have one part, so nothing is getting shipped.
    Now the 555 is only one tiny example of things going
    this way. And I am not telling you guys not to use it
    because I know everybody uses it, and it is everywhere
    except in HP equipment and the like because they forbid it.
    I made the mistake of telling a Tektronix engineer one day
    that that mess of transistors could be replaced by a chip.
    He told me, "Yea, but I can always get transistors".
    Now don't jump on me saying I am telling you to make
    everything out of individual transistors, because I am not,
    and I don't want to spoil the fun here, but doing this stuff
    for real, and that IS what you guys are suggesting, may
    require more thought than which micro is better.
    Which one can you get? This doesn't even mean that the
    companies aren't making the part, but if the new wizz bang
    part is popular and others are ordering it, like in large
    quantity, all of a sudden you can't get any for a year.
    Carl you should know about this where you work.
    Now think about what is happening to those companies
    while they can't get that part any more. Yea they are
    once again redesigning the product, and not to make it
    perform better, often it will be worse, but to get it back in
    production.
    yea i know, no fun, shouldn't spoil the dream.
    • enter
      this
      is
      all
      interesting
      but
      do
      you
      think
      you
      could
      press
      enter
      a
      bit
      less
      often
      What about pic 16F91XX any problems with that
      • Originally posted by JC1 View Post
        {and if you do this for real you will find this very important}
        I work on the PC software end of data acquisition with some embedded work. However I’m sure that my views are representative of the Eng. I work with.
        Originally posted by Delbert grady View Post
        this
        is
        all
        interesting
        but
        do
        you
        think
        you
        could
        press
        enter
        a
        bit
        less
        often
        I'm still trying to work out if it sharky with his 'I'm Indian and going to steel all your work' in disguise or a detector manufacturer trying to stop this before it gains momentum, hmmm... maybe both LOL
        As with microchip these days, probably. It's always worth a shout in forum.microchip.com to double check the peripherals.
        • JC,
          I agree with your concerns. Hammerhead uses the 555-cmos and 74HC221, the 555-bipolar and 74LS221 won't work. I've run into this snag with builders. So usage of these kinds of multiple-technology chips should be accompanied with a clear explanation of which ones will work. Same thing with power, say, when a compatible part would work but burns 3x the power.
          Except for truly narrow-market semi-custom ICs (say, a GSM handset transceiver), most chip companies run products for no less than 10 years and usually 20 or more. Product design cycles are a year or more, so a chip won't even see volume sales for a year or two after intro. They typically peak 5 or so years after intro, then very slowly tail off. It varies market-to-market, but that's generally true.
          Fortunately, there are a lot of common pinouts that make substitution reasonably easy. Single, dual, and quad opamp packages, ferinstance. So there is a lot of flexibility. But, yes, chip selection needs to be taken seriously.
          • Hi Carl,
            Hey spell it out all you want.
            It will still get messed up. OK, maybe not, but I've only seen
            the other side. Where it does for various reasons, over time.
            And a "new" parts person really messes stuff up.
            I consult, so am not there all the time to hold their hand.
            And I'm not saying no one should use a 555.
            I would never want to get blamed for that.
            In fact in a very very mind warp kinda way you could even
            consider it a Microprocessor, and then by default it would
            automatically become a DSP processor.
            And instead of saying you couldn't use it, you could make
            it the Only part you can use...
            That would max out the ol profit charts.
            Yea yea i'm sharky and I'm going steal your designs.
            median filters, moving averages.
            That is too funny.
            • The game now
              No guys I won't be joining any design teams and this is not
              an insult, at some point in your lifem if you are lucky, and
              maybe work hard you will accumulate enough that the game
              becomes more one of not getting sued. Which is about the
              only way to lose a bunch of it, so I don't sign anything
              I can avoid signing and drive very very carefully. So I
              probably will not have access to the "secret DSP codes",
              and all the other great ideas. Oh well, have to do it all
              by myself, again, one more time, story of my life, all
              the heavy lifting. Just wish I could steal something once.
              Guess not, thought I had everybody fooled, but then you
              figured me out.
              • Actually
                Actually, I am consulting/working right now.
                {Didn't think I was going to do this without getting paid}
                {Did you?} It is State of the Art, but mainly it is
                State of the Nerves. Posting is more fun, and thought
                maybe
                someone wanted to do some heavy hitting on the DSP.
                I don't do any metal detectors except for fun.
                More money in gvrnmant {and they got alot of gold}
                so even quit picking it out of the ground once I figured out
                I could get it delivered to my home mailbox.
                And alot more of it, I can actually eat off of this.
                I turn down work on a monthly basis.
                Send them to my friend engineers.
                And I know ALL the EEs in this area,
                and they all know me.
                  Although I often use the term in discussing LRL manufacturers, this is just good ol' fashioned Wallet Mining, which is almost always more profitable than Gold Mining.
                  • Wallet Mining???
                    No No I mine the gvrnmant, they already mined everybodies
                    wallets. Just trying to get it back. You know like
                    Robbing Hood.
                    • Noble Cause
                      Hi Carl,
                      Here's a Noble cause to go on. Checking out bridges.
                      With DSP. Now design a good one of these and you too
                      can benefit from things like gvrnmant money.
                      Back on Topic.
                      Design and evaluation of an inductive Q-detection sensor incorporating digital signal processing for imaging of steel reinforcing bars in concrete.
                      http://www.iop.org/EJ/article/0957-0...3BGM294J3Ai7Kg
                      {Also has nice simple and I guess correct equations}
                      • Big Bucks
                        Or another alternitive would be to go for the Big Bucks.
                        http://www.squidoo.com/treasure_hunt...etal_detector/
                        DSP meteorite detector !!!!
                        • Too Funny
                          It says Mr. Bean up on the main forum thinggy.
                          That is too funny.
                          I was born on a farm.
                          Help me.
                          Really
                          Rowan Atkinson was born on a farm in Durham on January 8th, 1956. He got his Electrical engineering degree on Oxford university. His comedy career started at the Edinburgh fringe. He was also a late member of "Monty Python".
                          http://www.geocities.com/TelevisionCity/5349/biogra.htm
                          • "Is DSP useful? "
                            Yes it is!
                            "Is DSP only way...."
                            No is not !
                            " Is DSP best way.."
                            No is not!
                            "Is DSP needed mostly here..."
                            No is not!
                            "Are all members here interested much for DSP..."
                            No! Most of members are not! Most of members doesnt give a shi(f)t about DSP!
                            Best regards!
                            Good health to everybody!
                            • are Mr Bean and Roberts and JC1 all the same person
                              • Well
                                Hey Roberts !!!
                                Like the addy.
                                and the comments.
                                Might as well have fun.
                                All the good stuff is "secret".
                                Oh well, probably would have just stole it.
                                Yea right.
                                Dang Robbing Hoods.
