Carl,Max,J Player etc etc
  • Carl,Max,J Player etc etc
    whats the slew rate of this noise less circuit from the site http://www.national.com/ms/LB/LB-52.pdf
    Dont assume and dont think, say exact if u know, say the numeric figure....
    Some Read
    Here is some help.
    I can't think.
    Therefore.
    http://users.ece.gatech.edu/~lanterm...ors/AN-222.pdf
    http://www.national.com/ms/LB/LB-19.pdf
    Have a nice read.
      0.775 nv/rtHz
      Hey Sharky,
      You read Application note 222? They have 0.775 nv/rtHz amp
      in fig. 4, in fig 5 they have wideband 1MHz 2.0 nv/rtHz amp
      don't know the slew rate, probably have to figure it out from
      the other link I gave you. How far you planning on slewing
      anyway?
        Originally posted by sharky View Post
        whats the slew rate of this noise less circuit...
        Looks like 0.1V/us, good for audio.
          Resistor element Break Down Voltage
          Originally posted by JC1 View Post
          Hey Sharky,
          anyway?
          Planning for 50v/us for PI....15V/us is insuffient and also the resistors 2 watt type MFR have an element breakdown of 200-400v we need a high element break down voltage
            50 V/us
            Hi Sharky,
            Why 50 V/us ? that seems awful fast and very wideband
            and very noisey because of wideband with.
            Remember this is all per rtHz.
            Also remember you can put resistors in series to get higher
            and higher breakdown voltage on array. I often make large wattage
            and high breakdown by series and parallel many 1/4 watt resistors
            cause I don't want to wait to order and lazy and have lot of
            1/4 watt metal film resistors around, and they get rid of heat
            well this way as well. You can also follow the topology of the
            circuits and use your own favorite lower noise transistor and build
            your own amp.
              Nice talk JC1
              Hi Sharky,
              your own amp.
              Nice talk JC1, can u suggest a good PI, can i go for delta Pulse schematic in this site
                sure
                Hi Sharky,
                I haven't built the Delta Pulse, but in reviewing the schematic it
                looks O.K. to me. I like the DC restoration stuff in it.
                The transmit current in the coil looks like it is only limited by the
                the transmit period, inductance of coil, and DC resistance of coil.
                Therefore with low inductance and low resistance could get some
                very high transmit current, which is OK for detection but battery
                may have to be large.
