Air Core Coil Sim
  • Air Core Coil Sim
    Has any of you used this program to make your coils?
    http://www.coilgun.info/mark2/inductorsim.htm
    This calculator is not really suitable for designing metal detector coils. It's aimed (no pun intended) at solenoids, and can only provide calculations for a maximum outer diameter of 100mm.
      It works up to 500mm !
      500 mm x 0.03937 = 19.7 inches
      Thats more then I would need.
        Yes, you are correct.
        There is a radio button at the bottom left, where you can toggle the maximum range between 100mm and 500mm. However, this calculator is still intended for solenoid design.
