Detector input overload
I have seen many complaints from detector users, that say they have to use the detector with the coil several inches above the ground, otherwise the input overloads due to the high mineralization.
I believe this problem could be solved if we had some solid information about ground conditions. However this information is difficult to standardize.
So lets see if we can find a way to simulate the amplitude of the ground response.
A common, quite universal target we could use as reference, is a steel bottle top.
Questions:
Holding the coil in the air, how close below the center of the coil can you place a steel bottle top without saturating the input of the PI or VLF detector?
How far can you detect the same bottle top in the air?
How far can you discriminate the bottle top?
How far can you tell the difference between a bottle top and a copper coin?
The above tests being done with the bottle top in the flat position.
Now repeat the same tests with the bottle top on edge.
What are the results?
These results could help me a lot in designing a detector that has a good working range in high mineralized ground.
Tinkerer
Questions:
Tinkerer
-- I lift detector a lot anyway to check the target for depth and size. But if overloading causes completely missing target, then it is indeed an important problem.
