Tweaking the HH
Your coil looks good and you still have the possibility to improve the balance.
Looking at the scope picture:
I assume that you are using a x10 probe. If this is the TX and RX signal, you are using a 18us Tx pulse.
To be able to Discriminate FE, you will have to improve the balance.
Try to move the loose part of the lead of the bucking coil, while observing the scope. If you see any movement, adjust so that the TX pulse goes to 0V.
If this does not work, try adding one more turn to the bucking coil and move this around.
If this does not work, you have too much feedback, meaning too many turns on the bucking coil.
If you do not want to undo your coil you have the option to reduce the current in the bucking coil.
Tinkerer
Originally posted by GT Blocker
Tinkerer
