Hi Paul,
thanks. Indeed, I lost this picture and the corresponding spice model. Anyway. The picture shows the conventional difference amplifier with low input impedance. There is an inherent attenuator, which allows early sampling.
A true instrumentation amplifier design should increase the input impedance without attenuating the signal.
The idea behind making the coil driver symmetric is the following: The leakage current through the FET and drain diode will be compensated (eliminating offset voltage). Any temperature dependency of this too. Particularly both parts have high temperature behavior.
Alternating pulses will produce less heat on the parts too.
Balancing is quite trivial and can be made with different solutions.
In the coming days, I will order the mentioned inst. amps.
Hi porkluvr,
I meant driving altenate transmit pulses of course to get alternating magnetic pulses. One could also drive simultaneously to increase the coil current (parallelling the coils with same phase). A differential signal won't be there then of course.
NEW !!! Full differential PI front end.
Whew. Aye, of course that's the only way that it could make sense. That might have been obvious to you all along but this thread has been a bit over my head for some time now (er, from the beginning). I'm not trying to throw barbs but only to understand as much as I can. Thanks for clearing that up.Originally posted by moodz View PostHiya Pork .... umm I think that we are talking about alternate pulses being of opposite flux not the same pulse or they would cancel out.
moodz
Some of the ideas here seem to have been over-simplified, and I might take other ideas to be more complicated than what is needed. It's hard to know the one from the other.
This discussion is interesting to me because I have a design that needs two transmit FETs, to either feed into two separate coils, or else to feed the two ends of a differential coil. Your starting this thread came at a good time, but the ideas can be hard to follow.
Actually, I would not need two seperate FETs except for a desire to degauss. Unfortunately, my two transmit channels have different pulse streams, so there will not be equal but opposite fields, and demagnetization will not be complete. I would like to find an EASY way to remedy that, but I don't see it happening any time soon.
I have not been following this thread too closely (I get tired of the drowning sensations) but still I try to grasp the concepts presented.
Hi all ... here are bench results for v600a schematic ..
PIC 1 balanced flybacks at either end of coil.
PIC 2 o/p from diff amp ( green ) vs MOSFET gate drive ( white )
PIC 3 o/p from diff amp ( green ) with target vs MOSFET gate drive ( white )
As you can see you dont need fancy bipolar flux capacitors
to get good results. In fact the balance circuit consists of two 10K resistors.
moodz
for reference to the current discussion ... credit to Aziz ....
... http://goldprospecting.invisionplus....l=differential
... and repost because I think Aziz lost the original ...
Originally posted by porkluvr View PostI was having a hard time following this discussion, but now I am totally lost. I can understand how two opposing magnetic fields would degauss the ground when they are temporally displaced, and there could be a usable signal to process. But if these two opposing fields are transmitted at the same time, then it seems to me like they would cancel each other.
So, when the net residual magnetism of the ground equals zero after swinging the search coil, it wouldn't be because of alternating fields wiping the other's residual, it would be because of opposing fields cancelling each other.
There would be no residual magnetism to degauss in the first place.
If the two opposing coils and their transmitted fields were precisely the same but opposite, wouldn't the net target excitation be zero? This train of thought might be the result of my ignorance and two dimensional thinking, but to me it seems very rational.
Hiya Pork .... umm I think that we are talking about alternate pulses being of opposite flux not the same pulse or they would cancel out. Some mine detectors use this type of AC pulse as a monopolar pulse can detonate some types of antitank mines that are sensitive to magnetic fields ..... at least I think thats what we are talking about
moodz
Hi Aziz ... I tried something like this but found that the capacitance on the 'balance' or turned off fet does not discharge enough between pulses thus affecting the balance .... this cap needs a leakage resistor or a quick discharge pulse on gate.Originally posted by Aziz View PostIf you don't use bipolar transmit pulses and second switched-off FET stage, just add a high voltage adjustable capacitor parallel to the below coil half to achive capacitive load balance. Below part can then be omitted.
But the symmetrical FET stage has a better CMRR and PSRR. If the coil driver is made for true bipolar transmit pulses (totally symmetric coil driver), this should have the best performance. It will also degauss the ground!!!
moodz
I was having a hard time following this discussion, but now I am totally lost. I can understand how two opposing magnetic fields would degauss the ground when they are temporally displaced, and there could be a usable signal to process. But if these two opposing fields are transmitted at the same time, then it seems to me like they would cancel each other.Originally posted by Aziz View Post
... If the coil driver is made for true bipolar transmit pulses (totally symmetric coil driver), this should have the best performance. It will also degauss the ground!!!
Hi all,
here is, what I mean. If you don't use the bipolar transmit pulses (alternating coil current), one can even balance the coil driver with a second switched-off FET stage (see below). The capacitive load of the coil ends to ground should be almost same. The FET below may also avalanche. It adds some capacitive load into the coil.
The differential stage will "kick" the target stronger compared to single ended design.
AzizAttached Files
Hi Aziz,Originally posted by Aziz View PostHi all,
I would take two same mosfets and drain diodes with single coil power supply. The capacitive load to the coil ends should be almost same. A simple passive adjustment circuit could correct any inbalance.
As the transmit drive would be ignited alternately on the coil ends, a bipolar magnetic field emission occurs automatically even the coil is driven with single power supply.
You can make the design either with P or N channel mosfets. P channel mosfets make the MCU design a bit easier, as the center tap of the coil can be put to ground. With N channel mosfets, ground must be set to the battery +. The analog front end should have a bipolar power supply (like +5/-5V or something similar).
The dual supply design has some advantages as the maximum voltage at each resistor is half the max voltage seen across the coil. The two diodes will isolate the coil and if there are imbalances then this can be trimmed out as you have indicated.. The two damping resistors centre tapped to ground would have to be matched very closely and tied to the same common point to ground. The second advantage is that there is a better choice of MOSFETS as the voltage does not have to be as high . A 200 v MOSFET will give me 400 volts prior to avalance.
The Instrument amp would need to be dual supply and the INA163 is a good choice. As I will be using MOSFET for signal input switching there is still a good choice of 250 V signal mosfets to choose from.
Now have just to build the beast. I don't expect it to be easy.
Stefan
Hi all,
Hi Stefan ... yes the dual supply is the obvious extension of the designs in this discussion and I have built a bipolar version with only minor differences from what you describe ... however balancing is more difficult as the switching decays on the switch devices must be identical / matched. My other reason for not progressing to this type is the added complexity which I am trying to avoid.Originally posted by Stefan View PostThe .pdf file attached is an output copy of an LT Spice simulation using a dual supply.
It looks very similar to a differential signal as posted on this site previously.
The circuit design consists of a +6vDC -6vDC supply connected to two mosfets ( P and N) with the 300uH coil in between. Blocking diodes are connected on each side of the coil. Instead of having a single damping resistor across the coil, the resistor is centre tapped and the centre tap connected to ground. The coil floats between the two blocking diodes and the mosfets and referenced by the damping resistors to ground..
The file shows the resultant measurement of both sides of the coil with reference to ground. I will be building this using 200 V rated mosfets and the Instrument amplifier will be the the INA163. I like the INA103 ( BW better) but the minimum power supply is +-9VDC so the INA163 is a good replacement.
Stefan
Anyway good luck in your investigation ...
regards,
moodz.
Another method for differential input
StefanAttached Files
These look like excellent choices and even work out much cheaper that using 3 OP37's for my differential input preamp.Originally posted by moodz View PostHi Aziz ... the SSM2019 looks really good .... 1nv noise
$A6.60 here in oz
I will wait to see what you discover ... good find !
paul.
Tinkerer
$A6.60 here in oz
paul.
