Minelab MPS patent could be invalid
  • unregistered_user
    You do judging by your avatar!
    Oh sorry you mean RF guru?...that would be me.
  • Woody.au
    "A small number of reexaminations are initiated by the patent office itself. These are called “director initiated” reexaminations. They might be filed when a patent of questionable validity attains a lot of publicity. The director, for example, ordered several of the reexaminations of the NTP, Inc. patents that covered BlackBerry mobile email technology."
    So who has an RF background?
  • unregistered_user
    I wonder if Poole was **** at math?
    His explanations just breath with translucense.
  • unregistered_user
    It seems that background cancellation by the comparing the linear aproximation of exponential decay in a metal detector is covered by this Poole patent
    Compare Fig 1 with my description of the SD2000 and where the samples are taken notice the clever way the first and last samples are subtracted ............by design? OMG!!!!
    I can see all Poole needed to do was use his other patent as well and he would have an SD2000 just imagine what you could do with todays zero drift low noise stuff? All he would have had in those days was a 709.
    OK to be fair Poole doesn't mention taking a sample with no pulse to cancel background noise
    Nor does he mention being able to fine tune the slope of the linear exponential decay aproximator (I must look more into that).
  • unregistered_user
    Of course once you move outside the "traditional PI" detector sample window the worlds your oyster.
    There's nothing to stop anyone sampling the entire return and throwing away the bits they don't want.
    Anyway the much more interesting feature of the SD2000 is the variable slope linear aproximation of an exponential return comparator for want of better words. With low frequency and no return or background "ground cancellation" again with variable slope linear aproximation".
    Now there is an area ripe for mining.
    Simple and eloquent. And if not already clearly in the public domain.
    Anyone else notice that?
    Anyone care to draw the detection window and compare to various patents claimed....?
    Roby?
  • unregistered_user
    It possible that amplitude saturation compensation might also be of benefit to metals detectors.
    Roby what do you think?
  • unregistered_user
    How's this for a new project guys?
    A Frequency Flexible Vector Network Metal Detector that uses in part or combination but not limted to synchronous detection wide band or narrow band in combination or singly, pulsed and or continous wave in combination or singly that compares ground returns with ground + target returns using mathmatical transforms implemented in software or hardware in combination or singly the frequecy or time domain in combination or singly. Using both phase and amplitude information in combination or singly. Data can be stored or processing can be done in real time. Presentation to the human operator can be audible or visual
    Claim1 For the purposes of significantly removing ground returns more than one frequency is transmitted into the ground and the return is measured differences in frequency only will remove a target from ground clutter.
    Prize for the first poster to come up with a diagram, start with Pooles Fig1 if you like resistors on the coils are optional and you can use one or more coils
    Just an idea.
  • unregistered_user
    Such as treating the ground as an S paramater network and use standard vector network technologies. Compare the difference etc etc Patent that! If you can get away with it now that I've mentioned it.
  • unregistered_user
    Today of course there are much better ways of extracting the ground returns by using more than one frequency in a metal detector in the frequency domain as first pointed out by Poole its quite trivial.
  • unregistered_user
    Regarding the overall significance of Candy's inovative use of anothers patent with obscurantism it occured to me that to try and claim infringement of his own patent wrt to using 2 frequencies to significantly reduce ground returns and comparing the difference of those returns due to frequency alone then he would have to concede that there is a direct recipricol translatation between Pooles analog frequency domain inovation into a digital time domain solution and compare the results mathmatically to prove his case.
  • unregistered_user
    And this.
  • unregistered_user
    Sorry Fred I don't want to create the wrong impression that's all.
    Who knows where this will lead and perception can be spun into a negative.
    I certainly don't condone censorship in any shape or form whatsoever.
    Now onto a more fruitful topic.
    I commend you all to listen or read this behind the office door presentation from patent litigation expert.
    It seems to cover the lot.
  • unregistered_user
    Pooles precience still amazes me.
    Now class for home work read Poole's paragraph 70 and tomorrow bring in your copy of Fig1 with the wide band detectors and bandpass filters that Poole foresaw would solve the ground problem.
    Yes bug_whiskers you can use lock in amps as combined narrow band filters detectors, everyone else was supposed to work that out for themselves remember to use the right frequencies for your lock in amps though.
    Roby...still haven't finished yet? Tomorrow perhaps then?
  • Qiaozhi
    Originally posted by Fred View Post
    Thanks Qiaozhi,
    What i mean is i that i don´t know is if there is international agreements about patents .
    And this only as personal curiosity about how things works in the world, i have no comercial intererst on the matter
    Hi Fred,
    Nor do I.
  • Fred
    Originally posted by unregistered_user View Post
    Originally Posted by Fred
    Can it be exported then to the country where the device is patented?
    If so,with the actual globalization, patenting anything would be almost a nonsense...
    I repectably suggest to the moderator and to you Aziz that talk of illegal activity be considered with great caution. Aziz you actually stand to benefit if you play by the rules.
    And those rules apply equally to anyone found out no matter how respectable they have appeared up until now.
    So lets just keep this legal, on topic and in the spirit of honesty.
    Thank you.
    Are you crazy? i just asked this to understand how things works, and you call for moderation and censure ?
    You seem to be very touchy on the subject, but it is not by hiding facts that you will resolve eventuals problems.
    No ... if something is considered a patent infringement in another country, then you cannot export it to that country.
    Thanks Qiaozhi,
