Hi.
Yesterday i went for test with TDI and 12" coil at a place where there are a lot of stones and ceramics from an very very old village that now don't exist. I must say that i had detected this place a lot of times before, and last times without any result.....
I adjusted the TDI at 10us, GB=on, GB at 9 (at this place it made ground balace), all conductivity and sensitivity about max.....(not erratic signals). I went up of the ceramics without any any problem
. I found only some rust iron objects at distance from5 to 20cm. Nothing deeper
I wanted more depth.....
But the basic problem is that with this adjustment, detector must give a high tone at rust iron objects and NOT low that gave to me. So today i made a some tests at Lab and i attach here.
If you will look carefully, you will see that there are some holes....
I am interesting about gold, silver and copper, and to reject the rust iron and the ceramics. There is not a adjust for it with a "good" depth. So i must make some adjustments so to see what is down the earth.
On top of the table you will see the detecting depth without ground balance. Sensitivity is set a little low because inside the lab i had erratic signals.
.I wanted more depth.....
