Hi all, unfortunatelly I am back again
I tried to close it in grounded alu case and walk in nearby forest (actually I live inside this forest), but results are the same.
I made 1st TGSL by Qiahozhis complete details with all parts the same like in schematics. Then I made DD coil. Inductances are practically exact 6 and 6,5mH (I used 0,3mm magnet wire so coils has lower resistence than those from manual). I shielded them (Thinnest aluminium I can find -> 15-20mm wide strip with 3-5mm overlap of turns and 5-10mm gap in shield). I measured resistence across shield and it was conductive (few ohms). Shields are connected together with Tx- and grounded in box. I tried to ground Rx- to shields as I saw in some schematics, but even this does not help.
Does it matter where I connect this? I mean Rx- with shields and Tx-? If join is in coil or in the box? until now I always connected this on coil end of cable.
So I thought Its a PCB mistake -> made new pcb -> this time TGSL EDU (only difference is J113 instead of BF245c, because I dont even have J107 and I am out of BF245c). But troubles remains... So now i suspect the coil/shields. I used thin alu sheet. Shield itself does not change inductance remarkably - only 0,03mH for each and the same direction - so this has no efect to inductance at all.
This alu shield is total mess. Lot of work against few minutes of spraying... I still have coils not diyed in enclosure so I still can take down this shield and make conductive enclosure with clear coils...
Do you have any susspects in this case? I do not have any original coil so I am not able to check this. I can make photos or video about this, but text is always faster.
Thanks for any information!
All the best, Tomas.
