Disconnected coils from each other and placed them in bigger overlap so it doesn't overload and start beeping
tried to wave with ferrite ring 3.2 cm and I can't set trimmer to eliminate it
it comes close to it ... eliminates it close to min. GB but it lasts only 5 s and then it beeps again
TGSL Tuning & troubleshooting
Replaced capacitor to 10nF... nulled coils at 45-50mV
detector starts to beep when I get close to that position and keeps going untill I turn it off
GB on min. stops it for few seconds
tried turning it but with no help
stops only if I bend coils from that position
sens pot is on min. or close to it but it doesn't matter if he is on max or min.
1nF is too small. Try with 10nF and see if you can ground balance your device. You know, find a piece of ferrite and wave in front of your coil, while trying to silence the response with GB pot.
started 4.5V AC and got to 40mV AC
barely made it... it was harder to find this spot with this capacitor value in place (1nF)
Increased phase shift with reduced capacitance is confusing.
Can you achieve under 100mV at pin 7 in balance?
that screenshot is not my nulled position - or we should quit that for now
after that I made one more screenshot (moving coils to point where it should be)
my first capacitor in RX is 15nF
I can desolder him and check capacity with LRC meter and confirm with regular multimeter and then ... replace with lower capacity
I have 1nF and 10nF in that range
The first graph indicates a phase shift between Rx and Tx, and according to the X-Y plot it is over the recommended maximum ~20°. I'd say the Rx coil is too close to resonance, and reducing a parallel capacitor would reduce the angle between them. The Lissajous curves are quite useful for measuring phase between two signal sources. I can conclude, by fitting your curve with mine, and stereoscopic visual inspection, that your Tx/Rx angle is 23°.
See for yourself...
Looks like something is oscillatingOriginally posted by sdesic View PostUsed TX and pin7 on X-Y graph
made it pretty
adjusted phase so few lines are drawn ... I think
as I don't know what I am doing
GB on max (down)
K1 and K2 connected
[ATTACH]25102[/ATTACH]
Should be an ellipse - the angle of it depending on phase shift between disc and Geb gating signals.
S
GB will only change phase so I suggested you to try x-y plot where it is visible.
Try to replicate situation where you have the delay after turn-on, and seek a waveform that turns on with it. Once you find it yoi'll know what causes the delay.
