TGSL Tuning & troubleshooting
  • sdesic
    Here are two screenshots 10ms and 90ms
  • Davor
    You are mostly interested in envelope of the signal, so you may increase a time base to 10ms, or even 100ms and it will give you a somewhat less confusing display. This is a nice display of a signal sampled near Nyquist frequency, and there is nothing you can do to make it better with the existing soundcard. It would improve if your sampling rate is 96k, but it is unlikely that your soundcard supports it.
  • sdesic
    same pic ... sorry about that
    here it is again
Name:	RX - pin 7 preamp NEW.jpg
  • sdesic
    and RX on pin 7 of preamp and ground
Name:	RX - pin 7 preamp.jpg
  • sdesic
    Scope with pot and one capacitor - with short cable gave good results without signal connected
    with connection parallel to TX - screenshot
  • sdesic
    This is screen capture - sound card oscilloscope with 100k and 22k resistors
    connected parallel to TX coil
Name:	without connection.jpg
    and with nothing connected to it
  • sdesic
    I don't know if it is my audio card oscilloscope or it is problem with MD.
    I will try second probe - with resistors only and post screenshot again
  • porkluvr
    Originally posted by sdesic View Post
    Moved coils from that nulling point an it is working Ok again ... less depth but working
    From looking at your oscilloscope photos in #1126, you have a bad problem either with your test apparatus/technique and/or the transmit section has serious issues.
    Don't fool yourself into thinking #1126 is OK. That looks like nothing but noise.
    Fix your transmitter, and then you can worry about null.
  • sdesic
  • sdesic
    Made new nulling and got RX coil to get 2.1mV from starting 150mV
    BUT after that I can't stop detector from going beep beep ... 4x second
    if I flex coil it stops little and starts in few seconds again... pots are not responsive
    LF353 PIN7 soundcard probe capture
Name:	scope pin7 and gnd.jpg
    geocamp close to former gold mine... nice
  • Davor
    Preamp, or preamplifier is a thing that follows after a RX coil. U101a, pin7 is the preamp output. The best point to stick your soundcard probe is at a resistor R27, as it is firmly on DC ground potential, and it's upper end has only AC component on it.
    BTW, I might attend geokamp in mid June, see http://www.kresevski-citrin.com/inde...d/14-4-geokamp
    Could be interesting
  • sdesic
    You must find points with low impedance to avoid loading your device with a long cable and low impedance.
    Start with Tx, but make a 1:10 or so attenuator, just reverse the resistors as seen in http://www.ledametrix.com/oscope/
    Next connect a scope (with 1:1 probe) to output of preamp, and re-do coil nulling.
    The most important thing is to supply your device with batteries, as a PC PSUs are not famous for their isolation.
    I have made fist one with potentiometer 50k and one capacitor 100uF 16V
    Working on battery power.
    Špansko selo je kod mene - preamp output ? It's easy to say if you know
  • sdesic
    Two scope screenshots TX signal
    Difference is time scale
Name:	scope tx 2.jpg
  • Davor
  • sdesic
    Done first two and now I have some kind of scope. Soundcard scope.
    Here is screenshot.
    Fist test without anything connected
    Tested output from speakers - loop - sound generator from this fine software
    Triangle from signal generator
    What to test first on MD ?
    Where are test points ?
    Looking at TGSL 101 from Don but don't know what are safe points for my audio card scope.
