TGSL
Dear Simon
c6 0v
c12 650mv
c15 116mv
rx 6.30 26ohm
tx 5.85
thanks
TGSL Tuning & troubleshooting
What is inductance of RX coil? And resistance?Originally posted by metaldetector107 View PostDear Simon
my scope not ready sorry, but Fr at 2n2907 collector is 14.7-8
at pin 1 of 4024 is 14.6-7 at pin2,6,7 of lf353 is 14.6..
the detection depth so poor also very very unstable despited tested shielded coil
Rx v 0.2 to 4 mv.
any help warmly recieved
Can you measure the Rx capacitor C6?
Please measure DC voltages at C15 and C12 (relative to ground).
-SB
TGSL
Dear Simon
Rx v 0.2 to 4 mv.
Then we have no problemsOriginally posted by metaldetector107 View PostDo you have an oscilloscope?
yes i have
We just need to see waveforms like first few posts at the beginning of this thread.
Also coil parameters (TX, RX inductance, resistance, size). And what is your coil shield like?
-SB
I harp on this a lot, but it is very important to test far away from EMI noise. I know, because in my "workshop", I cannot get more than 15 - 20 cm depth, even with dfbowers excellent MD, due to some EMI noise from somewhere.Originally posted by metaldetector107 View PostHi
sorry the frequency is 15.1khz my meter battery was out so gave the
wrong value, ok the problem is i cannot make it quite it cracks
and detectiond range so poor.
kind regards
-SB
TGSL-EDU
Hi
kind regards
One thing I do is tie the anode end of the diodes to +12v with a 10k resistor. I usually hook into to my "power on" switch for +12v. That way, you get a constant tone in the speaker while adjusting turns on a coil. I turn the volume way down on my head phones. It should not hurt anything to let it run like that for extended periods.Originally posted by simonbaker View PostHi metaldetector107:
Many times it is the frequency counter measuring double the frequency because of some problem.
Can you check with scope?
dfbowers mentioned a method to listen to the speaker tone when detecting a target and compare it with musical instrument to match the tone, and you can figure out your TX frequency.
Photos of your circuit top and back might help.
What test equipment do you have?
-SBAttached Files
Hi metaldetector107:Originally posted by metaldetector107 View Posti have build tgsl-edu board, only i hear cracks and the frequncy around
27xx khz which should be 14xx first time i did put lf353 wrongly .
please i need your help
best greets
-SB
First thing you need to do is isolate what the problem is on the frequency. If the coil is the proper inductance then it has to be in the oscillator circuit. At least it is oscillating even if it is way too high so it should not be hard to track down. Much better than a dead board
Jerry
TGSL
best greets
Thanks Qiaohzi
Thanks Qiaozhi for moving the discussion of simple high-voltage coil driven by sine or square wave to other thread.Originally posted by Qiaozhi View PostI think I've moved the correct posts. However, the move process only allows me to select one page at a time, and the posts get renumbered after each move. If any of them are wrong, please let me know. In general, please try to make your posts in the correct thread, as moving multiple posts can be somewhat tricky. I have already refused some previous requests due to the sheer number of posts that had to be moved.
Location is now here for anyone following:
-SBAttached Files
I will prepare photographs of instrument tgsl 3 and coil and selfinduction resistance coil,
and I will go up him in the internet in order to him we examine.
I thank
It depends where you are testing. EMI noise from electrical lines, etc. in your home can limit detection to 16 cm.Originally posted by fmnotes View PostHello.
I request a question.
I have made tgsl 3.0 version.
detects 1 Euro in the 16 cm
it is well?
if exists problem,
say me what I correct.
I thank.
But if you are far away from electrical noise, you should expect around 25 to 33 cm air test according to people who are good at building the TGSL. I'm sure you have read the results from Ivconic, Max, dfbowers, etc.
So... tell us more details, show photos. Give specs of your coil (size, inductance, resistance, TX frequency, shielding, cable wiring, etc.).
-SB
Hello.
it is well?
if exists problem,
I thank.
