Originally posted by dfbowers
... relieved also that I didn't put a whammy on it somehow...I seriously have thought about a Faraday cage... and maybe raising chickens too. I wonder how big it would have to be to not interact with a coil...
Of course Qiaozhi's advice to not take air tests too seriously is a good one and something to be tested if possible. The real test is in the ground. But I look at it this way:
First, getting a successful air test of around 30 cm means you have at least reproduced the design as others have and gives you confidence your parts, wiring, and coil building are normal.
Second, although a "noisy" ground may obliterate the very small signals that make the difference between 20 and 30 cm air test, there may be occasions where the ground is very favorable and an optimally built TGSL will pay off.
Third, I would ask, is it possible for a TGSL that air tests at 20 cm to actually hunt deeper in soil than a TGSL that air tests at 30 cm? Perhaps yes, and if so, we should look into why and how. But our instinct is, a 30 cm TGSL should do as well as better than a 20 cm air-tester. Still, if they are virtually the same in all ground, then I agree, don't sweat it. My own feeling is that the beach is a special type of ground well-suited to deep detecting and I would want to know I can get 30 cm with my TGSL.
Since eventually I would like to experiment with even deeper and more sensitive designs, I'm a little stymied about how to efficiently do that, given the noise limitations in my work area. Right now it looks like it would involve a complete wire-up and trucking to a remote area for testing. Probably not too feasible in pre-retirement days. I'll do what I can. Maybe I'll end up in a cage one way or another.
-SB
. . Divide and conquor!! Now we need to come up with a noise reduction scheme.. Isn't that strange that detection range just sucks sometimes for no apparent reason? We all need to build Faraday cages around our workshops!! I was in a lab once in Harrisburg that had one.. It looked like a chicken coop.
... but feels like it sometimes
