Originally posted by dfbowers
Over the last 2 weeks, I built 2 more coils, trying to independently determine what the best shielding and grounding configuration might be to deal with wet grass. Having 3 coils that worked very well, they all suffered when the sun went down and the lawn was dew covered.
I put all theory aside and went with some trial and error.. Plus what I thought would make sense. A little costly I think but did come to a solution which works best for me.. (your milage may vary).
Never mind what I tried and did not work.. it doesn't matter. What finally DID work is this:
A USB-2 cable, using all 5 conductors (2 power, 2 signal + ground).
* RED and BLACK wires to run the Tx coil (since they are a heavier gauge).
* GREEN and WHITE for the receive circuit.
* Rx and Tx shields tied together in the coil and wired to cable shield.
Cable shield is then tied to ground on PCB.
* Rx and Tx coils NOT connected to ground inside the coils at all.
In other words, all active parts of the coils do not touch the grounding
system in any way.. Only the cold end of the Tx circuit is connected to
ground on the PCB.
Null was less than 100 mV at pin 7 of U101a but climbed to 300mV when epoxy cured.
Best airtest without chatter on 1e is 31cm with latest coil.
Best airtest without chatter on 1e with coils wired per TGSL coil making by Ivconic is 35cm (indoors).
Depth test in hard packed clay test garden. 16cm for .58 Cal minie ball. Same for all 3 coils .. about the same as my Shadow X5. ($935.00 machine).
I know that some post will agree with my wiring configuration, some will not.. These are just my findings.
I also vacuum formed a new shell and managed to shave 3 ounces off of my previous coil (the one closest to the bottom of the picture..
Don
ground on the PCB.
Don
. But I'm going to hammer this point because I think it is particularly important for this thread (tuning and troubleshooting), and I think it is possible to have weird null phase with no problem and trying to fix it is waste of time. But null phase may also be a warning that something else is wrong, like TX frequency is too close to RX resonant freq, etc.
