TX for Messina
The idea is TX to be powered without voltage stabilizer for maximal efficiency. The oscillation amplitude is
stabilized by P-I controller. For its reference voltage is used a LED. Thus, the amplitude of TX
oscillation decreases with depletion of the battery, but this change is slow, so no impact.
Problem for a powerful TX is the battery voltage and its weight. The idea is to use 2 laptop battery packs for power supply
and to use the laptop for battery charging.
For simmetry, the TX coil consists of 4 equal sections, 0,3 ohm each. So the maximum of pumping
current pulse is Im=21/0,3=70A. For observation of current pulse is used resistor R9 made of
brassleaf. This allows to adjust voltage divider R5-R6 for maximal undistorted amplitude.
The SPICE shows that circuit can work well with only one NMOS.
The circuit diagram is an idea only.
It can be 4-5 ohm or more low .You can ,
