ARADO 120 SCH& PCB
  • #31
    Originally posted by ANDREAS View Post
    Yes, but is not time for this. We wait the first PCB
    hi sharky i cant found 3v9 diode any solution ? and for cd4017 i have hct4017
    i will star my pcb after solving this 2 problem br!
    • #32
      Use other jener between 2V9- 4V1. I think you have not problem, if we see problem.. sorry but you must be find 3V9 jener. Use Hct4017, i am sure... it's work. C17,C18 you don't put now your PCB. After resonate Tx coil, you know if C17,C18 are right or not
      best regards
      • #33
        Yes is true , but my Arado build two years ago, i don't put this variable capacitor.
        You know is very difficult resonate same two coils Tx/Rx. For this application Arado use this variable capacitor.. etc
        My method is simple for your all. After you build PCB , you must build a electronic-cap with range 50-300n. With this electronic-cap we can make a fine tune Rx coil.If you find this parts (example 101,5n) then replace with normal capacitor/capacitors and only difficult point is a "null" Tx/Rx. With this method we don't need variable capacitor between Tx/Rx
        best regards
        Hi Andreas
        I find it interesting how your finely tuned.
        Have you a schematic for electronic-cap ?
        • #34
          Hi Patrick
          I wait finish the first PCB , next step are coils and finaly is electronic varcap.
          best regards
          • #35
            Hi Andreas
            To give Thanks for your Nice work .
            Best regards.
            • #36
              Thanks Andreas, it looks like nice basic circuit to try.
              No ground balance I think.
              If Rx resonant to Tx frequency, that is nice for sensitivity -- but will it stay in tune? Maybe drift easily?
              I hope people build and try it in real ground, very interesting.
              Cheers,
              • #37
                Thanks Andreas for this interesting project and wonderful explanation.
                Can't wait to get a break from my day job and start building one.
                • #38
                  Has anyone completed one of these yet ? I am interested in the "OO" coils, perhaps as replacement/upgrade for original machine ?
                  • #39
                    Ardo has very interesting detectors.
                    • #40
                      Im going to build this detector, has anyone else here built it?.
                      I have a small varibal 150pf out of a radio if required, seems by old posts that was the only bug bear.
                      Dave
                      • #41
                        hi Andreas, congratulations for explanation, please tell me coils are shielded?
                        thanks
                        • #42
                          HELLO EVERYBODY!
                          COULD SOMEBODY TO TELL ME ABOUT THE COIL OF ARADO 120 (HOW TO MAKE IT) AND HOW I WILL ''NULL'' IT!
                          THANKS
                          • #43
                            WHICH IS THE PURPOSE OF VR1 TRIMMER???
                            • #44
                              Originally posted by nimalgr View Post
                              HELLO EVERYBODY!
                              THANKS
                              https://www.geotech1.com/forums/foru...0023-arado-120
                              • #45
ID:	428060 Click image for larger version
ID:	428061 Click image for larger version
ID:	428056Click image for larger version
ID:	428055 I Click image for larger version
ID:	428063 Click image for larger version
ID:	428062 have made the Arado 120 as the schematic of Andreas....the circuit worked, but has low volume and low sensitivity (depth). Could someone to tell me if the shielded coils Tx and Rx, is possible to prevent the sensitivity of this machine. The pcb is the original from Andreas. I have maked this exactly the same.
