NOCTA detecor
  • NOCTA detecor
    Please share some experience about this kind of detector NOCTA ,OGM ...
    ALSO ADVICE FOR BEST CHOICE FOR SEARCHING GOLD
    For searching gold you use Minelabs PI from 2100 to 4500 or Whites TDI
    NOCTA ,OGM ... and such expensive kindergarten toys are unusable for gold prospecting.
      Nokta you may be meant of... sh-t of #1 degree. there are many talented bunco-steerers around the world... you are right that go on the forum and ask suggestion. keep yourself far away from the frauds!
        It depends what type of gold is being searched for. If it's gold nuggets, then yes a PI is a good choice. If it is gold coins, then something else would be more appropriate.
          Agree. But if target is deep and in heavy terrain, no matter in what form gold is, only mentioned PI's are usable.
            WM6 - Are PI machines you recommend same or similar to Deeptech GP4500?
              According producer data, much better than DeepTech GP(Ground Pioneer)4500 can be one other Bulgarian brand PI, Mikron made:
              http://www.mikronbg.com/Stinger2.html
              Very promising data, can be ML and TDI chalenger, even better in some feature, but .......
              ... practical experiences with this Bulgarian detector(s) are not known to me.
                thank you on suggestions
                Idea is to search for all king of gold mostly in hill , or mountain
                all king of gold , please from experience and best satisfaction tell me
                what is better to use minelab or white's
                milab vs white's and whites
                DFX 300 DFX XLT
                vs
                spectra V3i (any experience with this detector )
                thank you in advance
                  what about OKM beside NOCTA
                    DFX 300 DFX XLT
                    vs
                    "for all kind of gold mostly in hill" the best and not to expensive solution is Whites TDI. Probably you need additional coil for it, so you can build your own or buy some other brand even used ML coil suit well to TDI.
                    Look at more info:
                    http://pulsescantdi.com/intro.htm
                      thank you on help ,
                      what is more expensive and better if have better for searching in hills
                      /than suggested /what will be for step upper in quality and performance give couple examples
                      if someone have
                      any experience with White's V3i , please give comment
                        Are you looking for gold nuggets or gold caches?
                          he seems looking the new advertising of Nokta sh!ttector. these guys hope on good deep WEB searching indexing of the forum and their bullsh!ttector will found over by a naive people.
                          here is not Baghdad for you. here is Stalingrad!
                            Hello Carl , how are you
                            most of all I like to search for gold coins,and similar things made from gold ......
                            what is your personal opinion about V3i
                              no I do not search for ****TECTOR ,,
                              I like to know the truth ,about OGM nocta and sililar detectors , because it LOOKS very scientific
                              bdw what about anderson rod PMRI I , II and III , also ****tector
