Are they beating a dead horse? And is it time to move on (at least for some of us)?
I refer to one of the last posts made by Ivconicin the original TGSL construction thread and I quote:
10-03-2009, 04:45 AM
ivconic ivconic is offline
Guru
Default
Older Tesoro models like TGS,Silver,Bandido etc..etc.. do have pretty limited area of detection. If you manage to make good 27cm DD coil to reach 1e coin up to 34cm in air than that is it. Only much larger item it will detect a bit better. So it will stay limited to those 34cm and less (soil conditions). Same thing with smaller diameter coils. Recently i made 21cm DD coil and it is performing pretty good - 1e coin at 27cm in air. No false signals, very stable, excellent disc. Excellent performing on soil. And very loud and sharp audio!
But... larger items it is also detecting up to that limit...maybe 3-4cm more. No matter how large is the item - similar "depths" in air.
So...it is limited. It is not about TX power here. TX power at TGS/TGSL is quite enough. It is much more about RX stage and coil.
I had some doubts about that, but than i got original Bandido II and i noticed same occurrence and behavior. So...it is not about my (our) handmade - it is general.
Once i realized that i just took it as reality. TGS/TGSL is good as it is. Best you can do is to put more effort to make and balance better coil. With my previously balanced coils (in the past) i achieved some 36 to 45cm in air for 1e coin, but than i realized - no benefit from those on real soil, depths in soil were same as with latest coils (1e at 30cm). Only differences between those coils (in the past and recent) were in residual voltage and audio strength. In the past i kept residual voltages under 1mV and got more inches in air and...very weak and mum audio. Nowdays i keep residual voltages around 4mV and benefit is loud and sharp audio. On soil those coils performs, as i said, pretty same.
So it is all for-each-other very dependable! Very important to know this!
"Chain reaction". Coil dictates all the rest in detector.
Conclusion;
not much sense in modding the rest of schematic if coil is not done well.
So i suggest to you to also take 4mV residual voltage at RX as MUST default. I made over 35 coils so far and that's how established this - pure rough experience, statistic and practice.
That was also the main reason why i insisted to get any similar original Tesoro - to see what is situation at those, originals.
I think those at Tesoro also realized this long time ago. Newer series (Tejon,Vaquero,Cibola etc..etc..) acts much different than older series.
I had chance only to check Tejon and Vaquero on soil. I hadn't chance to open one of those and trace out some stages. Pity. But also i measured coils which came with those. Much different coils than those we make here!
Inductance at newer coils are much different - looks more like Minelab coils for Musketeer and RH....some ~1mH for TX and ~14-16mH for RX!
Newer Tesoros now are not looking "limited". Meaning large items those detecting at much more distances!
I am looking forward to see some traced out schematic from newer Tesoro. Mostly am interested to see TX stage and RX front end.
Regards!
Guru
Default
Conclusion;
Regards!
Thank you in advance.
