Garrett Serial Numbers
  • Garrett Serial Numbers
    Greetings All !!!
    Hopefully someone here can solve the mystery since two different folks at Garrett couldn't -
    How do you decode the Garrett detector serial numbers? Specifically, for an ADS 7 (not a 7X), with the serial number: 2569-119, what is the year of manufacture and how do you know that?
    As I said above, I called Garrett and two different folks in Customer Service couldn't tell me. Any help is greatly appreciated !!! Thanks in advance.
    Originally posted by Pappydoodle View Post
    Greetings All !!!
    Pappydoodle, according a list posted by Homefire, model ADS7 was produced in 1984-1989:
    http://www.geotech1.com/forums/showt...eferrerid=2910
    I think may be -119 means month and year.
      Hi mikebg -
      Yeah, I've seen Homefire's info, and as usual, he's always on top of things! I also found some information on another site forum that breaks down the info even more specifically -
      "ADS 7 was made from 1984 to 1986, and those were made with the Deepseeker coils. Then in 1989 for one year they made the ADS 7 again and this time the ADS 7 had a transformer in it and took a Crossfire coil. Then in 1990 they came out with the Master Hunter 7X. So for one year they did make the ADS 7 with the Crossfire coil and not the Deepseeker coil."
      The above quote was taken from a reply to coil questions and was provided by a person at Garrett !!!
      Here's my problem - I have an ADS 7 I bought off the EvilBay. It came with three coils, all with five pin, female connectors. The coils have a Garrett sticker on them that says they're "Deepseeking" lightweight, foam filled, and waterproof." The "target center" indicator is not an "X" but more like a shooter's scope crosshair sight.
      I thought like you, that the last three digits in the serial number were for the month/year - November/1989. If that's true, this detector should have a Crossfire coil, not any type of Deepseeker/Deepseeking coil. Maybe that's why it's not working properly. Regardless, when I called Garrett, two people told me that the detector was made in the 87-88 (???) time frame. I'm so freaking confused, I don't know where to turn. Some other info about the coils and this detector:
      As I said, the coils that came with it are five pin, female connectors, the older Deepseeker coils are four pin, male connectors which won't work with my ADS 7. I hate to spend $50-$75 for a Crossfire coil if that first quote above is incorrect. Thanks for the help.
        Pappydoodle, I posted in the section "Modifications" very efficient improvements tested in Garrett Marksman PB and ADS III. Despite your model is "younger", I think they are applicable for it too:
