I use polystyrene 12 x 24 sheets. I got them off ebay awhile back 25 sheets of 1/16 for 50 bucks shipped. The guy who sells them has no more. I recently asked. MEK will dissolve styrene. You make a slurry with it. It's what the coil manufacturers use to hold their coils together. I use it to bond plastic pieces to weaker areas inside my shells for strength and to attach the ears which are solid polystrene. Also if you develope any stress cracks the slurry seals it right up permanently. Like I said before I want to make the lightest coils I can and use as little epoxy as possible. Most are well under a pound.
Bob
Bob
Nylon nut and bolt is used and cable is shielded, no way it would work as good as it does without it.
