BASCOM AVR RS485 PRINT/INPUT STRING PROBLEM - HELP!!!
  • BASCOM AVR RS485 PRINT/INPUT STRING PROBLEM - HELP!!!
    I'm programed in Bascom AVR-u RS485 communication between ATMEGA128 - master and ATMEGA32 - slave.
    On Slave display have problem receive chr(10) as first character in string.
    Test programs :
    $regfile = "m128def.dat" 'Master
    $crystal = 10000000
    $hwstack = 32
    $swstack = 20
    $framesize = 40
    $baud = 9600
    Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , E = Portc.3 , Rs = Portc.2
    Config Lcd = 16 * 2
    Cls
    Cursor Off
    Config Com1 = 9600 , Synchrone = 0 , Parity = Even , Stopbits = 1 , Databits = 8 , Clockpol = 0 ' MUST MATCH THE SLAVE
    Dim S As String * 8 , S1 As String * 8
    Config Print0 = Porte.2 , Mode = Set ' use portd.2 for the direction
    Rs485dir Alias Porte.2
    Config Rs485dir = Output
    'Rs485dir = 0 ' go to receive mode
    Rs485dir = 1
    S = "08.03.11"
    S1 = "13:12:58"
    Lcd "RS485 sending."
    Wait 1
    Do
    Cls
    Gosub Rs485_send
    Loop
    End
    Rs485_send:
    Rs485dir = 1
    Print S
    Print S1
    Locate 1 , 1 : Lcd "S : " ; S
    Locate 2 , 1 : Lcd "S1: " ; S1
    Waitms 500
    Return
    $regfile = "m32def.dat" ' slave
    $crystal = 10000000
    $baud = 19200
    $hwstack = 32
    $swstack = 40
    $framesize = 40
    $baud = 9600
    Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Portd.6 , Rs = Portd.4
    Config Lcd = 16 * 2
    Cls
    Cursor Off
    Config Print0 = Portd.2 , Mode = Set ' use portd.2 for the direction
    Rs485dir Alias Portd.2
    'Rs485dir = 1 ' go to send mode
    Lcd "RS485 receiving"
    Wait 1
    Do
    Cls
    Gosub Rs485_read
    Loop
    End
    Rs485_read:
    S = " "
    S1 = " "
    Input S
    Input S1
    Waitms 500
    Return
    On Slave LCD receive
    S : chr(10)08.03.1 not received 08.03.11
    S1: chr(10)13:12:5 not received 13:12:58
