pi coil connections
  • pi coil connections
    in different pi designs some coils are connected to v+ like in the hammerhead and to v- in the surfmaster.whats the consensus on which is best ?
    LOL! What's best ? PNP or NPN transistors both do the job.
    Just depends on how you do the job!
      if the coil is connected to ground and the sheild is connected to ground might the capacitance be less ?
        hey homefire .quit with the LOL .it's a valid question
          Sorry! I don't see that it would make any difference. Neg or Pos ground it's all the same.
          How would it effect the C ?
          Now that's funny!
            any shield is gonna add some capacitance .yes ? no ?
              The shield just diverts the EMI and Ground Cap away from the signal on the coil.
              Pos or Neg it keeps the receive signal a bit cleaner.
              The shield it's self adds a bit of Cap to the coil but the Benefits out weigh the bad.
              Does that make sense?
                have a read homefire http://www.irf.com/technical-info/appnotes/an-940.pdf
                  I see there talking about Grounded Load, but can't find anything about Capacitance problems.
                    you'll agree thou we are talking about 2 different animals .one will be different better of worse than the other for our needs.unfortunately these pdf's are not targeted at pi metal detectors.
                      I'm no longer sure what your trying to ask.
                      You asked what would be best and there is no difference. Neg or Pos Ground.
                      The use of P channel Fet ?
                      There are a number of ways to Fire the coil.
                      Transitors work Jim Dandy on some detectors.
                      A little help here.
                        like i asked at the start
                        i'm here to learn thats all.
                          They only thing I can tell you is that would depend on what parts used and how you have it set up?
                          I really don't think there is a best in regards to Pos or Neg.
                            Less than what? Where do you find any PI@ where the coil and shield are not connected to ground?
                            Your original question was not whether to connect the coil to ground, but whether to connect the coil to B+ or B-. (Isn't that what you really meant?)
                            In the vast majority of cases that answer simply rests on whether using N or P devices because that will determine whether B+ or B- is connected to ground.
                            @ There are some but they are not a majority.
                              hammerhead 1
