whats all the hype regarding the arado?.i've never used one just read all the accounts of how good they are ?
arado
Arado
I had a 120 as I remember in the early 70s. It had excellent depth. You could differentiate the good readings from the bad even with really weak sigs. The magic was in the zero center meter. If the meter went upscale or stayed steady you were good to go. If it dipped at all.... forget it
The new one 130?... looks good but seems like it is way overpriced for what it (supposedly) does......
thanks mudflapOriginally posted by Mudflap View PostI had a 120 as I remember in the early 70s. It had excellent depth. You could differentiate the good readings from the bad even with really weak sigs. The magic was in the zero center meter. If the meter went upscale or stayed steady you were good to go. If it dipped at all.... forget it
