I was looking thru some older "Gold Prospector" and "ICMJ" magazines the other night and came across a ad that seemed interesting. It was for a device that had two metal probes that went into the ground and injected an AC current into the earth, which was supposed to cause a "Halo" effect around metals and increase the ability of a VLF machine to pick up 4x the depth. I wonder what would happen if you used the ac output from the VLF machines to drive this device if it would work better (using a FM wireless mike on the VLF detector and a small FM reciver on the ground transmitter so the signal would have the exact frequency and phase?).
I know that you can inject an AC wave into the earth (via earth rods)and use a loop to receive the signal for Induced Polarization Surveys, which might end up to be the new wave of Gold Prospecting as IP is the most accurate method so far (see www.seg.org, goto the Publications section and goto the Archives of "Geophysics" for further info on Induced Polarization-epecially Sept./Oct. 97 issue).
Would appreciate any input on the VLF enhancement idea.
Randy Seden
Simi Valley,CA.
Randy Seden
Simi Valley,CA.
