Pulse Master Pro - a look inside & some questions
    After I read one of Tinkerer's messages on a forum thread ,where he mentioned that a large gold chain gives less signal then a smal gold tooth filling , i changed my test item that was a gold chain whit a ring , and gues what?, it detects it no problem. The chain was about 15 gr. and the ring about 5gr.
      Pulse Master Pro under side
      Hello dear SOVEREY, how is the name of this IC ?
        selam
        ben türkiyeden katılıyorum kabul ederseniz beni merhaba lar selam
        http://www.youtube.com/watch?v=XNG0rR9DXyM
          Please make your posts in English, or provide a translation.
          http://www.geotech1.com/forums/showthread.php?t=10526
            hi humhum
            i know
            plz send full photo in my email
            email : [email protected]
            i send number ic
              hi humhum
              plz chek your email
              thanks
                Originally posted by mahd313 View Post
                hi humhum
                plz chek your email
                thanks
                Hi Mahd313, I also need software for PIC18F2525 Display driver of Pulse Master Pro ,do you have?.
                Thanks for your interest or solidarity.
                  hi humhum
                  I sent a number ic to your email
                  i have not software pic 18f2525 but i can write software for atmel avr
                  and we should use atmega8 replace the pic18f2525
                  in (Your photo) is not part of the sound and power supply
                  plz send full photo to my email
                  thanks
                    Software
                    Hi to all, Need Software PIC18F2525 Display driver for ''Pulse Master Pro''
                      PIC18F2525 is locked
                        1x1m coil information? and photo inside pulse master pro
                        hi humhum
                        i have not software pic18f2525, but i am programmer (for pic & atmel microcontroller)
                        i need schematic pulse master pro for write software pic18f2525
                        and need information ( coil 36cm ) & ( 1x1m frame ) pulse master pro
                        wire=?
                        turns=?
                        resistance=?
                        and i write software pic18f2525 for pulse master pro and send for you
                        sory , bad write english
                        thanks
                          Hi mahd313
                          if you failed is simply integrating the electronic circuit of the project hhd ver c + electronic circuit to LCD For presentation and separation of metals like dp2 Turkish ver 2.
                          And their work mixing + Soft new you can get.(as you say i am programmer for pic & atmel microcontroller)
                          best time
                          j.
                            Hi to All , Please help me with this two parts value R1 and R2 = ? ohm
                              scheme electronic
                              i need a scheme of pulse master pro .exist?
