PULSE RATE - pulse repetition rate (10/20/30/40 pps)
Foxylab I am curious for your reason why you choose a very low pulse rate ?
Arduino metal detector?
FoxyPI v3
The third version of pulse metaldetector on Arduino Nano (FoxyPI v3) (transition to the use of the Arduino ADC and dynamic mode) is ready.
Firmware (hex-file) and description (on russian, edited under the third version) - https://acdc.foxylab.com/node/47
Test video -
Originally posted by Joo View Post> I want to make VLF MD with Arduino Atmega328, what is the scheme of the front (Coil and Buffer) so that it can be connected to the Atmega analog pin?
Hex-file FoxyPi (version 2.11) for Arduino Nano 3.0 - https://acdc.foxylab.com/sites/defau...aloginputs.hex
How to flash (in russian) - https://acdc.foxylab.com/avrdude
What is the VD3 in the Schematic ?
- The spec calls it a 3pin VRef .
- But the schematic shows its config as a Diode.
How do I connect this ?
lol it go`s to sign wave when metal is near the coil im using a lm358 opamp
In your screen shot it goes from some what square wave to sign. What's that about ? Try adding the Cap. See what it does.
i replaced R8 with a trimmer to fine tune the gain i dont see no ringing it only changes when it detects metal ? the cap works to i used a 101 cap
Added Trim. Series? Parallel ? Or Replaced R8 ?
Looks like the output of Op Amp is ringing. That's why the Erratic indications I bet. I don't know what the Hysteresis or trigger level is on the Arduino.
I assume this is BreadBoard work ? Add a Integrator section with off set adjustments and I bet this thing will work quite well taming down the ring and getting the Arduino input stable.
Just Thinking here. Try adding like a 50pF in parallel with R8 to Integrate the signal into the Arduino. See if things tame down some.
