Arduino metal detector?
Nice project! I have a few Arduino nano here too. Eventually a nice winterproject;-) Good work!
i think you do good work with this fast optocoupler und the mosfet driver ic
New version of MOSFET driver:
It combines speed and performance at lower supply voltage.Attached Files
depth -Originally posted by jlsilicon View PostWhat results, depth, dicrimination, etc - do you have for this MD so far ?
discrimination - not
results - see above in this thread
see details here (in russian) - http://acdc.foxylab.com/node/47Attached Files
Important note. Thanks!Originally posted by Altra View PostNice project Foxy. I have used the HCPL-3120 before to drive mosfets and they work great. But they have one draw back. There is an under voltage lockout feature which if the battery voltage falls below 11 volts it turns off. There are different versions, some cut off at 10v some at 11v. See data sheet for "UVLO". So use 12 - 14v for your power supply as Foxy did.
I assembled the stand to test them:
I will check and let you know the results.
P.S. I plan to top-middle of July to prepare a public version foxyPIv2 software.Attached Files
Nothing wrong with your English!Originally posted by FoxyLab View PostThanks!
I bought a HCPL chips from this seller on eBay: http://www.ebay.ca/itm/5-PCS-HCPL-31...-/261366995287
Driver v1 - simple circuit, but slow off the MOSFET -> low voltage peak in coil -> low sensitivity (excuse me for my bad english
Driver v2 - complex circuit, faster off the MOSFET (description of similar circuit in russian http://radiohlam.ru/raznoe/driver_polevikov.htm). I met the description of a similar scheme in the French engineer, but lost the link.
Driver v3 - a simpler scheme than the Driver v2, but sensitivity similar to Driver v2.
Thanks for explanation!
Thanks!Originally posted by ivconic View PostVery well done!
Lot of useful observations on original page.
Very well done!
Can you explain here all the advantages/disadvantages between the 3 versions of the mosfet driver?
HCPL-3120 is maybe hard to obtain; so i would rather chose version 1 or version 2.
Version 2 looks more interesting.
My current circuit for foxyPIv2 Arduino-based MD:
(description (in russian) - http://acdc.foxylab.com/node/47 )
I experimented with pulse durations up to 750 usec.Originally posted by bernte_one View Post400V peak, look good
whats is the longest pulse you can produce without heating the coil driver too much?
P.S. I got a chip HCPL-3120. My current MOSFET driver circuit:
