Arduino metal detector?
  • MartyJ1963
    Hiya Useus,,,,Ignore my last post,,,I managed to open the file now,,,Thanks, Marty.
  • MartyJ1963
    Hiya Useus,,,,Thanks for the files. Is there a Sprint layout for the pcb please? I'm having trouble opening the Gerber files in Sprin layout 6. Thanks, Marty.
  • FoxyLab
    Finds in our garden with FoxyPI (after electrolytic cleaning):
  • FoxyLab
  • FoxyLab
    The double-pole switch with locking in the neutral position and the digital LED voltmeter allow you to determine the voltage of the uC/power battery in any mode of MD operation:
  • useus
    these days I have designed a single layer version ready and finished.
    In the zip there is all that is necessary.
    Read the readme!
  • useus
    V0.8
    correct capacitor dimensions
    fixed an lcd connection
    improved component positioning
    as soon as the material arrives I produce this version
  • bernte_one
    for people without fritzing
  • useus
    reduced pcb
    small improvements
  • 6666
    Originally posted by FoxyLab View Post
    Hello!
    [ATTACH=CONFIG]49418[/ATTACH]
    Here are the signals at the ADC input - without a target (1), with a target (2). The upper horizontal line is the saturation of the ADC (voltage >= 1.235 V), then voltage gradually decreases to zero.
    Thanks for the info, cheers.
  • useus
    gnd improvements
    displacement components
    displacement tracks
    removed unnecessary capacitors
    added power input diode 1N5819
    wires size correction
    this is truly the last: P
  • FoxyLab
    Originally posted by useus View Post
    sure!
    however, it is also a convenience factor, do you want to have only one rechargeable battery pack instead of two stylus battery packs to replace when they are discharged?
    This is a purely subjective decision, due to this - a discharge of batteries for "digital" power will lead to complete inoperability of the device (therefore, before a long search, I fully charge the "digital" batteries), and a discharge of batteries of "analog" power only reduces the sensitivity of the device.
  • FoxyLab
    Hi Foxylab, just wondering when you monitor the output of the LM358 with a CRO, what is the voltage range between the highs and lows of the signal ? thanks
    like between arrows.
    Hello!
  • 6666
  • useus
    Thanks for hint. You are right with this batts.
    But 4% with 15 minutes is not big deal :-) And rebalance is "press btn -> 10 sec pause -> press btn -> READY".
    sure!
