IDX-PRO+VDI
  • Guest
    Guest replied
    Whites Classic 3.Two tons of discrimination. It's easy. The three channels work together. Click image for larger version
Name:	whites two tone.jpg
  • Uiliam950
    I'm waiting for the order for the capacitors to arrive
  • Emersonpaz
    After replacing the capacitors, is the board working again?
  • Uiliam950
    C8
    C10
    C16
    they are 1uf capacitors and at the time of assembly I got confused and put 1nf capacitors
  • Uiliam950
  • surfdetector
    Originally posted by Uiliam950 View Post
    [ATTACH]56175[/ATTACH]
    good morning I found 3 more wrong capacitors, these 3 marked in the photo I put 1nf and the project is 1uf I think this is the biggest mistake
    Can you post a copy of the schematic that you are using?
  • Uiliam950
  • Uiliam950
    Originally posted by dgm View Post
    Hi good morning, I think it is a problem in the metal detector you have assembled, in my experience before soldering the components on the pcb you have to check them with a tool one by one both resistors and capacitors, just a different capacity or resistance can give problems. Now check again all the components you have installed, even the potentiometers that regulate the GB, the TH, the Sens and Discr .. One thing you didn't say the problem you have does it only in all metals or in discrimination?
    the problem is with all metals because I can't get any kind of adjustment
  • Uiliam950
    what is the function of the 10k VR3 on the board
  • Uiliam950
    I think I put this capacitor wrong in the picture it shows 22 n this space means 220 n I think
    the correct capacitor is 22nClick image for larger version
  • dgm
  • Uiliam950
    I noticed that removing the U4 lm393 integrated circuit from the board it stopped bibaring and it worked normally, but with little sensitivity
    picking up a cell phone from 20 centimeters I have already put another new lm 393 in its place, but when I put it on the sound starts to crackle again
  • Uiliam950
    The coil must be connected to the metal detector once turned on, the RX coil must be blocked and the TX must be superimposed as in the photo sent by you, the measuring instrument must be connected on the two RX wires, and by moving the tx slowly check the voltage in alternating current as low as possible.
    Once a voltage of 8 - 15 millivolts has been reached, also block the TX coil.
    The coil must have the capacitors connected and the idx turned on.
    good night I adjusted my coil at the null point it is at 8 millivolts it has improved the sensitivity a little bit it is taking a cell phone at about 20 centimeters but it still continued with the crackling sound like it was passing some object on the coil
  • dgm
  • Uiliam950
    ok but I didn't understand this measurement of the null point it must be found the null point with the coils connected to the pcb and with the pcb connected to the 12v battery?
    and I have to measure the coils with the capacitors or without the capacitors
