Winding Spider coil
The winding of this coil is accomplished by starting in one of the slots and then placing the wire in the third slot clockwise on the opposite side of the ring. Continue clockwise with the third opposite slot until you make five complete turns around the ring and you will see that you are going to lay your wire in the next slot parallel with the prior winding in that slot. You do not want any parallel windings in the slots. To avoid this go back to your last slot where the wires crossed pependicular to each other and jog forward from there just one more slot. Then continue winding into the third slot on the opposite side for five more turns around the ring. Once again you will notice that you must jog one slot to avoid laying wires parallel to each other in the slot. They must always cross each other in the slots. Continue this until you have the requisite number of turns.
I used 26AWG enameled wire in the coil I wound. With the thin enamel insulation I'm sure the capacitance is significantly greater than it would be with teflon insulated wire. My next coil will be wound with 23AWG solid copper wire insulated with teflon. It is larger wire than I'd like but I have lots of it that I got for free by stripping out some CAT6 cable.
It took me a little while to understand what the Russian winding drawings were telling me but the pictures were truly worth a thousand words. I must be pretty close to a thousand words here already!
Sorry for the long explanation.
Happy winding!
Dan
Sorry for the long explanation.Happy winding!
Dan
