coil shielding PI
Thanks again for the clarification. Just laid down the first coat of graphite/polyvilylacrylic finish in a 50/50 volumetric mix. It will be dry enough to check in 2 hours but won't have anything definitive till tomorrow. Extra coats will likely be needed and certainly using your method of progressive ohmic checks throughout the coil will take some more time and adjustment. I will shoot for 1500 ohms/inch and see what happens in the field before putting on the final fiberglass layer.
Dan
Dan
