Originally posted by ivconic
as an example many times I found small bonze scraps and pieces (from helmets and armor and other things e.g. nails) at interesting depth and MORE depth that I can actually detect same items in air
that happens quite easy using very sensitive VLF detectors and also I can detect in very hard soil "halo" alone in a couple of times, I mean detector got signal from just pieces of compact soil not metallic targets , when targets were already removed
usually one cannot detect halo in normal soil cause when soil matrix broke (during excavation) the orientation of magnetic dipoles change randomly and they mix nullifing the effect at detector but in few cases soil is so dry and compact that it's possible detect halo in the pieces removed and that's possible also using PI MD , just subtle and easy disappearing once soil is disturbed
I stongly think that in very long time oxidation processes act on the soil matrix and disperse metallic compounds around, then something happens , maybe ionic exchange and flow of small earth currents in the matrix (cause of minerals in the soil and presence of a metallic mass of the target) and thus halo probably it's a combined effect of different causes, then when soil broke it easy disappear cause the equilibrium in the matrix is broken and then there remains few or nothing to detect about it
the really strange thing is the few distance of detection of very small items (thin bronze as example say 0.5 cm^2 area, homemade VLF + 20cm diameter coil running at 18KHz) in air or fresh buried BUT detected at 50%+ distance in undisturbed soil, with piece buried undisturbed for at least 1800-2000years , of course with thick patina, in that case green
this kind of stuff is the proof that halo exist otherwise is not easy to explain such extra detection range with such small targets
Kind regards,
Max
