More on two-box, CA3035, etc.
  • More on two-box, CA3035, etc.
    Taking the earlier quote from Carlos Daniel Fidel, and combining it with a definition found on the web AND after I learned that the spanish word "etapa" is "stage" we have the following description of a replacement for the CA3035:
    CA3035 replacement will be: A simple audio amplifier with three stages.
    Claus-Peter is wondering what type of meter will be adequate for the receiver in the two box design?
    All input welcomed.
    Update on CA3035
    I finally got around to looking at the 3035 problem in Rake's two-box design. The 3035 is basically a triple gain stage IC, each stage being a wide-bandwidth common emitter stage (see pic). It is NOT a diffamp-based IC like the traditional opamp.
    I think all that needs to be done to replace the 3035 is design a high-gain wide-band amp using modern opamps. Rake mentions that the 3035 in his receiver has a gain of 129dB. This exceeds the DC open-loop gain of most general purpose opamps and I suspect that Rakes means 129dB of DC gain, and somewhat less at the operating frequency of 180kHz. So if you try to use a GP opamp with the typical 1MHz gain-BW product you will only be able to get a max gain of 5 or so at 180kHz.
    One solution is to get some hotrod opamps. Since I work for Analog Devices and we make hotrod opamps, I've ordered some that should work nicely. The AD8031 (single) and AD8032 (dual) are capable of about 40-45dB (>100) of closed loop gain at 200kHz. Plus, they're single supply, low noise (~15nV/rtHz), and low power (800uA) - almost perfect for any metal detector receiver.
    When I get them in I will build up the receiver and check it out. For those who are truly interested I am willing to share a VERY limited number of samples. I think that anyone who wants can order samples from the ADI web site, www.analog.com. I don't know the procedure though, and would be interested to see if any common joe out there is successful with this.
      Charles Rakes two box metal detector
      Carl, can you help me with the CA3035 replacement?
      I´m building the Charles Rakes two box metal detector, but i can´t find the replacement for CA3035.
      On January 2007, im living on vacations and i have plans to carry three detector for field test, the clone pi, delta pulse and a two box MD.
      So, if you can help i ll really appreciate your suport.
      In advance many thanks.
      Nelson
      All input welcomed.[/QUOTE]
        If you go to this Link, You will find a Descrete Version of the CA3035 using Transistors.
        It has been tested and it Functions Almost Identical to the CA3035.
        Although I was Not very happy with the results I got with that detector.
        Nelson
        All input welcomed.
        [/quote]
          Besides Gary's transitor-level substitute, I posted an opamp-based substitute a while back, click here. And I agree with Gary, this is not a high-performance design.
          - Carl
            two box md
            Hey Carl and Gary, thanks a lot for your help.
            By the way, do you have any other two box detector that cab fit my needs.
            I really need to build one of this devices to experiment and compare it with delta pulse that i will carry on my next vacations.
            Nelson
              Here you can still buy the CA3035
                Thanks a lot for the information.
                Nelson
                  http://www.find-ic.com/partlist/CA3035.htm
                  YES, POSSIBLY. However you Will Pay a REALLY HIGH PRICE for it.
                  And PROBABLY you will need to buy a LARGE Quantity, or they won't even Answer your Request.
                    Thought
                    Hi Guys,
                    I would think a good approach to the replacement of 3035
                    would be a quad op amp with amps in series,
                    with each amp a simple bandpass filter, with a gain of
                    say 5 so 5x5x5x5 = 625.
                    The Q of each stage should be as high as can be practical
                    without being too selective or temp drift of the center
                    frequency could occur. Even lower Q after four stages would
                    result in a fairly sharp filter.
                      Originally posted by JC1 View Post
                      Hi Guys,
                      Hi JC1. From my experience a gain of 625 is low. We need a gain at least 10.000 so when we null the coils with full sensitivity to have a small signal at the output of Op.Amp
                        Whoops!
                        Hi Geo,
                        My bad !!! I haven't built a two box ever,
                        or looked at the designs very close.
                        Ok. Gain of 10,000.
                        10x10x10x10 = 10,000.
                        I forget the center frequency on these two boxers,
                        but could use from 1 kHz to 100 kHz for experimentation.
                        so for 100 kHz would need gainbandwidth for op amp
                        of 1 MegaHz. Many op amps could meet this requirement.
                        so selection of op amp would be for say lower noise.
                          links
                          Hi Geo,
                          I found a couple of links for doing
                          what I was talking about.
                          In both of these if you make R2 adjustable
                          you can "tune" the center frequency and get
                          everything just right even if the parts are 10%.
                            Free software
                            Hi Geo,
                            Here's a link for FilterPro.
                            You may already have this or something else,
                            but makes the design process quicker.
                              Hi Guys,
                              I Doubt that Bandpass filters is a good idea.
                              There will probably be a lot of Phase Shifting, resulting in problems.
                              The transistor circuit I show effectively gives the same results as the origional 3035 IC.
