After building Gary's PI detector and Trevor Hill's GoldPic detector I decided to purchase a Garrett Infinium. So far operation and performance seem on par with what the reports say and the ground balance and reverse discrimination seem to work as advertised (after finding out my cell phone causes issues with the circuitry).
Anyway, I'm a tinkerer and can never leave anything alone without trying to improve it. After seeing what my friend's Minelab GPX3500 can do, I was wondering if screwing around with the Infinium would be worth it (knowing my warranty would go out the door).
Some ideas would be hand selecting the FET (IRF640) and possibly the receive amp transistors. I say this because on the other two PIs I built, hand selecting these components did make a difference in sensitivity.
Also I noted a big difference in charge caps for the coil between different schematics. Some caps seem very small (47uf) while others at 1000uf or more seems to be to get charged and discharged at rates advertised. The Infinium frequency seems to be around 700Hz. So would increasing the cap, increase power to the coil and depth?
I would love to vary the pulse delay but being a uP controlled circuit that would probably require writing some firmware for the and the chip is probably locked or protected.
Anyone care to give some input on these ideas?
