do with the Fisher but with the Wave and it's clones.
Do you know if those also detect single hot rocks by
double-beep? Because this is a classic Fisher circuit feature.
And do you know how good is the bulgarian Pirate Black-Devil?..."
You have completely wrong criteria to suspect about Bliss origins.
Take a White's Classic as an example: it can "breathe" even more on hot rock than Bliss, but this doesn't make it "based on Fisher" machine.
Yes Wave is acting the same too. Many others too. Not strictly Fisher's "property"!
I don't know about Pirate Black-Devil. But i heard it is just another Wave variant too.
"...Concerning the XP Deus:
I guess it's a real good detector but it shows different
VDI numbers if the ground changes, the coil accu is
built into the coil and lasts just for around 10 hours,
the coil has just 22cm and the optional,
slightly larger one, costs 400 Euros plus! ..."
Not true! If it is GB-ed properly than VDI numbers are in proper range.
Even if not GB-ed perfect; VDI's are accurate. Numbers can varry in a very small percentage (up to 3%) in different programs.
I noticed small difference in displaying VDI number for same target in GMP and Fast programs.
Not big; but still there is a difference. Fast is more accurate.
So, we may say that only "Reactivity" (Recovery speed) + working frequency do affects VDI accuracy, which is in a way very logical.
Accu is easy replaceable. It lasts approx. 3 years before change (of course, depends on how frequently is used and in what conditions is kept).
Fully charged it can supply Deus (coil) from 11 to 20 hours, depends on working frequency and TX power.
These infos are valid for accus included in Deus v2.0 .
Look here: http://www.geotech1.com/forums/showt...633#post151633
22.5cm coil is extra deep considering it's size. Deepest coil i ever seen so far with such dimensions.
"...Sorry, but with such "problems" and that very
high price this detector does not deserve a 95% rating..."
What "problems" !?? I don't see problems at all.
About price... yes i agree, i would like to buy it for 100e too! :rotfl:rotfl:rotfl
"... The XP Deus may be real good for small sites with
alot trash to disc the shallow iron stuff but is unusable
for large "check out the area first" sites and for deep stuff..."
:rotfl:rotfl:rotfl
C'mon! What are you talking about!?? Who gave you such false informations!??
Deus is most versatile and most powerfull VLF/IB i've ever seen so far!
Even with smaller 22.5cm coil it is very deep! Deeper than majority of other top models.
The other day i dug 95cm hole!!! Large lead chunk was detected with smaller coil.
And i don't need to mention larger coil at all.
Listen; now reading your delusions and preconceptions: i am sure you never really worked with Deus.
Maybe you had chance only to see it for a short moment and that's all.
Even if you buy it somewhen; give it a time before you can judge about it.
It is not simple and easy machine as it looks. It is demanding machine. Need skills and understanding.
Cheers!
:disagree
