LORENZ
AFTER TESTING LORENZ DEEPMAX X6 I CHANGED MY MIND ABOUT THIS OVER PRICED METAL DETECTOR.(KELLYCO RETAIL PRICE 12999$)
WHEN COMPARE IT TO PS2 or DELTA PULSE IN SOME CASE PS2 or DELTA PULSE IS DEEPER AND LESS SOIL SENSITIVE.
DEEPMAX X6 IS VERY SOIL SENSITIVE AND HIGHLY AFFECTED BY MINERALIZATION .
the Delay system is nothing strange , many older device such Ps2 or Deltapulse have this item .
The data-logger is good but in fact do nothing more than audio signals.but in commercial advertisement it's very useful 'IT CAN SHOW YOU UNDERGROUND IMAGE
Target Classification is according the size !!:
gold range from 0-99
silver ,copper ,aluminum and copper also 0-99 according to size
and pure iron 0 to 60(factory said) but 70 (i tested)
the ferrous/non fe works only with the 35cm coil
and only very huge non-fe objects can reach 70 or higher at least 70cmX70cm or above 20 liters in one meter depth
i forgot to say that the Target classification program need a very very strong signal to work ,you loose every deep signal or small targets(under 1 liter vol is very small)
it means the discrimination works only with 35cm coil and for large frame coil it's absolutely useless.
The GBS system is a joke ,if this function enabled ,the MD become very very weak ; device only can reach about 1.5m deep in the soil, medium size targets and lower conductive objects like gold objects truly rejected.(X6 rejects an axe beneath the 1x1 coil!! with Ground 1)
the maximum depth in a place with low mineral ground with 2X2 meter coils about 3 meters for a 220litr barrel and 2m with 1X1 coil.
i discover some bronze non /fe metal objects with 2x2 coil (delay 1/Sens 5/ filter 3) those covered area about 1.5m *1m meters and in depth of 1.8 meters ,the target had really iffy signal , very very weak signal that truly i couldn't differ that signals with ground signals but we dig it up and it was a good target
i don't want to say that but i had better experiments with my old future voyager
i need a more powerful detector that able to detect a 50cmX50cm object in depth 4-5 meters
and give a good result at least truly distinguish metals and ground minerals
Can any body help me ?
maybe it was a GPR or magnetometer or ... something that really work and not like X6 only advertised.
!!!???!!!'Target Classification is according the size !!:
.i don't want to say that but i had better experiments with my old future voyager
, maybe Arash need contact with CIA
Lorenz is the average power to detect a disc 35 for a gold coin 45-50 cm
and for 20*20 target with 1*1 fram is 180cm The device does not work in any way weaken gbs pulse.
