Arduino based VDI!
Hello dgm
. It seems that the backlight command line is incorrect for your IC2 setup, I think.
"MD_V13:17: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'"
"MD_V13:209: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
MD_V13:209: error: 'POSITIVE' was not declared in this scope
lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);"
This is my setup
int backLight = 13; // pin 13 will control the backlight
digitalWrite(backLight, HIGH);
lcd.backlight();
Try to find out why its saying this error mesage "MD_V13:209: error: 'POSITIVE' was not declared in this scope"
I hope this helps!
Hi Mr. NĂ ndor, good evening to you and thank you for having responded, I checked what type of lcd I have is a 16x2 I2c, as I have already written I can read on Hello World, I found the right library liquidisplay_I2c-1.1.2 , And embedded menu system as Mr. Daren suggested, but I can not load the program. Below I'll make the mistakes found by Arduino:
Arduino:1.8.2 (Windows 7), Scheda:"Arduino Leonardo"
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6 _pin,D7_pin);
C:\Program Files\Arduino\examples\MD_V13\MD_V13.ino:17:80: note: candidates are:
In file included from C:\Program Files\Arduino\examples\MD_V13\MD_V13.ino:8:0:
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t)
LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:57:3: note: candidate expects 3 arguments, 8 provided
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
class LiquidCrystal_I2C : public Print {
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: candidate expects 1 argument, 8 provided
C:\Users\Home\Documents\Arduino\libraries\LiquidCr ystal_I2C-1.1.2/LiquidCrystal_I2C.h:55:7: note: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal _I2C&&)
C:\Program Files\Arduino\examples\MD_V13\MD_V13.ino: In function 'void setup()':
exit status 1
Thank you.
Hi, what error does the Arduino program shows to you? Have you checked your LCD adress for I2C? It is different than for direct connection. For me this was the first error :P have luck!
Hi Mr. HomeFire, thank you for having responded, my is a compatible micro arduino, recognized as a Leonardo. I also tried with another arduino uno a genuine but nothing.
Thank you for your time you use to answer me!
Hi, Good evening to all the members of this Forum. I ask for your help for a problem with arduino VDI, I can not load the sketch written by Mr. Daren (MD_V13), I tried in all possible ways, but I can not load it from many mistakes. I downloaded the bookstores reported by Mr. Daren but nothing, I can say that my arduino with liquidcrystal_I2C can load Hello World from the liquidcrystal_I2C-1.1.2 library. Please some of you who has had this problem can help me. Thank you for your kind patience.
All you really need is The chip, Regulator, Crystal and caps on rudimentary PCB. Plug the chip in a Uno, Program it, migrate it to a rudimentary board and your in. https://www.banggood.com/DIP28-ATmega328PPU-MCU-IC-Chip-With-Arduino-UNO-Bootloader-p-932159.html?rmmds=search
Mega2560 is really over kill for just the VDI. Remember Battery requirements would be quite higher then the little Nano and OLED. The little Nano will do the job and more. A little OLED would look snappy on a detector too. Enough Room on the screen for VDI, Battery Status and More. https://www.banggood.com/0_96-Inch-W...-p-932606.html
Hey folks. I am new to arduino but reading and learning a lot. Will i be able to use this lcd with the code given here? this is the mega2560 with 320x240 lcd. Thanks fort any assiatnce.
2 viewed per hour
SainSmart Mega2560 R3 + 3.2" TFT Touch LCD SD Slot + TFT Shield Kit For Arduino
2 viewed per hour
TGSL X/Y
TGSL EDU X/Y.Originally posted by Teleno View PostCan you help me ientify the R and X points for this project in the TGSL schematic?Attached Files
Can you help me ientify the R and X points for this project in the TGSL schematic?Originally posted by eduardo1979 View PostI did this project a long time ago, but it did not work very well. The VDI numbering is erratic. I will publish my design here according to the source code. The original design that was published by the author, does not work, because it is not compliant with the source code. I had to research and redo the entire design to make the VDI work.
Enjoy.
I dont know.....but the old Tgsl-VDI-project here in the Forum works well for me and isnt erratic;-)
bernte_one: Nice to hear from you....i wasnt too much in this forum the last time. I want to build this VDI with you.....but it will take a bit of time, because i havent too much free time in the next weeks. I dont know if i can really help you but im really interested in building this VDI;-). Eventually more people from this forum build this VDI with us???!!!! Lets do it!
