Hi
I've build the ETI561 as described here: http://www.geotech1.com/pages/metdet/projects/eti561/eti561_150.pdf
the red markte part below dosn't oscillate
I simulated the marked part with LTspice but the result was the same as in the real circuit.
The coil was wound on a 160mm PVC-pipe. ~60,75 turns, ~24,4mm length with 0,4mm enameled copper wire and has ~3937,5uH
The coil is connected with a shieled cable and a 3 pin XLR-connector
Here are photos of my PCB: http://info-tbb.de/~radic/mdt/
I hope someone knows what I did wrong.
