I think THAT 1570 would be a much better choice because it would enable you to supply it to a real balanced stage prior to the further processing. NE5534 ... is not a real difference amplifier because you do not have equal input impedances for differential input signal. A cross-coupled or Birt configurations would do that, yet neither of these, as well as your solution using a single NE5534 go down with noise.
There is a possibility to build a cost effective balanced CFIA solution using discrete BJTs in combination with cheap op amps. The same configuration is in THAT 1510, yet with not-too-good differential amplifier at the output.
In case you really wish to keeš NE5534, I'd suggest using NE5532 instead, but in a cross coupled configuration. It will provide balanced output which is good because you need reversed signal anyway.
