I have made a new coil from PTFE INSULATED EQUIPMENT WIRE, 7/0.15
10" internal diameter with 21 turns. I have a resistance of 2.9 ohms across the coil (out of circuit) I have set the offset to 0v after I noticed that I soldered in C13 the wrong way round. I put every component in carefully as not to get polarities wrong and still managed it
I binned the cap and used a new one just in case I fried it.
Anyway, I set the trimmer (delay) to the mid point but am getting slow pulsing through the speaker, I think someone referred to this as "ringing". To get the resistance to around 1.6 ohms I need to put a resistor in parallel which will block the coil, so what now?
I have ordered an inductance meter to give me an idea of the inductance of the coil.
I have a Caltek CS10H Scope which I have never used, so if anyone is willing to tell me where to connect it and use it to set this detector up, I would appreciate it very much
I binned the cap and used a new one just in case I fried it.Anyway, I set the trimmer (delay) to the mid point but am getting slow pulsing through the speaker, I think someone referred to this as "ringing". To get the resistance to around 1.6 ohms I need to put a resistor in parallel which will block the coil, so what now?
you need some form of insulation on the wire, that is to stop it shorting out between turns!
