It's no use asking PJ or UrbanFox questions as their technical knowledge and credibility is zilch. Each post they make will confirm this and expose their motivation.
Their rants are disrupting Aziz's contribution towards producing a better detector at a better price.
QED
I have not seen any interference/audio interaction when using my Minelab around other detector users. Admittedly, I would normally never detect within around 5-6 meters of another detector, and would typically give other detector users a reasonably wide berth in the field.Originally posted by dougAEGPF View PostWhat you refer to is modulation of the Rx audio much like AM/FM radio.It happens with ML detectors and perhaps some others?
I seem to remember a reference on your forum to being able to hear the local radio station through the QED audio. Was that a "design feature" also?
No matter how I tuned my Minelab, I just cannot tune in my local radio stations.
I have to admit, though, being able to hear the response from another detector could be good when instructing another detector user.
Also, you could have stumbled upon the design for wireless headphones there. Maybe another patent is in order!!
You have made the assertion that the QED has a problem with harmonics.What folk here would like to know i am sure is why you allege it has this problem and on what do you base your assertion?Originally posted by PATCHES JUNIOR View PostDoug your little game will not work here demanding answers to your silly questions. Lets see you prove it does not has a problem. Or why it not on the market after years and years of say it will be ready any day now. The ONUS is on "you" Doug after all your years of bagging.
Have you tested or used the QED? Is their a problem in the QED circuit or the circuit layout or any circuit components that is causing the harmonic problemt; if so could you please tell us? Are you familiar with the QED circuit and the MC source code? dougAEGPF
And please no silly name calling like on your forum. Lets keep it civil and not threaten with banning if you or I can not give you the answer you like.
Again Doug you are what I consider one of my best friends in the world!
What you refer to is modulation of the Rx audio much like AM/FM radio.It happens with ML detectors and perhaps some others? When one detector goes over a target if another detector is close enough then you hear the target response in this detector. ie the Rx audio from the first detector is modulated when it goes over a target and this can be picked up by the Rx of another. Can you show some CRO shots from the QED to illustrate the alleged harmonic problems it has?
dougAEGPF.
http://australianelectronicgoldprosp...y-bugwhiskers/
dougAEGPF
What would cause this reaction in a PI gold detector then if not harmonics?
I am sure you would be able to tell us all for the sake of science."Some time back I was out detecting/testing with Alluvium.
My detector was switched on and the coil was sitting flat on the ground. Alluvium was around 15 metres away and his detector was on also.
Alluvium dropped a $1 coin on the ground and proceeded to swing the coil over it. To my dismay I could here my detector's audio responding as if I was the one swinging the coil over the coin. There is no way that my detector was picking up the signal from the target but rather the modulation of Alluvium's TX field as he swung over the target".
Hi PJ,Originally posted by PATCHES JUNIOR View PostAziz, I know your mentor (Doug) follows this forum, but will not post for the reason of so many people think he a bit on the twisted side. But no need for you to be afraid of him here. I would sure like to see you produce a working detector with your world beating ground balance you brag so much about. I did not say your design has a harmonic problem. Just Bugwhiskers QED design has it. But both you and I know he will never admit it. Maybe in a couple more years of the "about to be done" statements it might be ready.
Here is hoping that soon you show the world your ground breaking, worlds best ground balance you have developed! Good luck, I hope you make a million!
I don't know much of the internals of the QED. But you are just speculating here.
Yep, the "MadLabs Inc." ground balancing is the "World's best ground balancing and discriminating technology". Even the ML (market leader) can't do it better. But the "MadLabs Inc." first mad engineer does it.
Who's going to make a million? Not me! (BTW, I'm scheiss reich! - I'm $hite rich!). I'm a poor-man's supporter. I rather would give the technology for free rather than seing someone else ripping off a lot of folks. Well, that's going to be happen some day. Who knows.
Cheers,
*LOL*
I see a lot of dis-harmonics!!! Between the finders and AEGP forum.
Beware of the non-synchronized harmonics. As long as the harmonics are synchronized to your experiment (measurement), they won't be an issue.
Very interesting!Can you tell me what circuit or circuit components in the QED that you allege are causing the harmonic problems and how,when and why they are manifested? Do you have the schematic for the QED detector or the source code for the MC? dougAEGPF
Hi PJ,Originally posted by PATCHES JUNIOR View PostWhy with all your smarts Aziz you are not helping Bugwhiskers and Doug get the QED working and out in the hands of blokes looking for a gold detector better than a Minelab?
why don't you and your smart mates help me?
I HAVE MASSIVE HARMONICS(C)(R)(TM) PROBLEMS!!!
Cheers,
QED
Why with all your smarts Aziz you are not helping Bugwhiskers and Doug get the QED working and out in the hands of blokes looking for a gold detector better than a Minelab?Tags: None
