External USB camera for droid phone for prospecting
  • UncleMatt
    Originally posted by bklein View Post
    Here's another approach - this camera is very popular with the xtreme sports crowd - now they say they will have a realtime/control app: http://gopro.com/support/article/?21500171 (still have to worry about doing the wifi above water level...)
    Barry
    Problem is, they are not small enough to go into cracks and smaller spaces though. I will keep looking and report back with any new finds.
  • bklein
    Barry
  • UncleMatt
    I just came across this youtube video that shows a guy using a small usb network adapter to make the camera above totally wireless
    I wonder if you had this camera on the end of a metal shaft and underwater if the shaft would carry the radio signal out to the air above to a wireless receiver? Any opinions on that?
    Now if I can just find a way to link the network adapter signal to my Android Samsung Charge running 2.3.6 Gingerbread, I will be making serious progress.
  • UncleMatt
    Why it works: Has a tech-savvy, digital marketing ring. Think “YouTube” + “marketing tape” for campaigns.
    Ooops, here is the 1080p fully submersible video camera I meant to post, and its $339! Yikes!
  • UncleMatt
    Here is a good camera for this, though it would require a redesign of the rear cap to accomodate a waterproof pass-through for a micro-usb cable, and a software patch to allow the video/images to go straight to the smartphone. Also has onboard battery, so smartphone does not need to power it.
    But $230...
    A less expensive option would be welcome, so if you see somethng better, post it.
  • UncleMatt
    Well, I was under the impression linux was used on android, but apparently there are differences in the code. I have found a number of people who are willing to design this code for me for a few hundred dollars. Call me lazy, but I would rather do that and get this operational out in the field quicker. I will report back with results when/if I get everything lined up on this. If anyone has first hand experience with an app developer and would like to refer them to me, let me know.
    Next challenge is powering the camera device. Many of the camera units available also have LEDs for low light conditions, and I think the phone would be challenged to provide enough juice for camera and lighting functions both. I am looking for a small submersible camera setup that has its own battery on board, or perhaps the battery could be mounted on the probe shaft in line with the USB cable. Of course, if a wireless camera is used, it will need a different setup.
  • UncleMatt
    I am aiming for a small submersible camera and cable that weigh next to nothing and take up very little space. I prospect in areas where I must hike in for many miles at elevations often above 10,000 above sea level. Under those circumstances you aren't really looking to add yet another display or additional weight to what you are already carrying.
  • bklein
    Originally posted by UncleMatt View Post
    Barry, I checked out wireless camera link, and love the little camera there, but its not an underwater capable device.
    However, it does bring up the fact you could use a wireless camera, with perhaps an antenna lead that would stay above water for better reception. That way you could have a long probe device, perhaps a telescoping affair, to mount your camera on so you could stick it way underwater (or way back in a crack or drift ). The antenna lead would stay on the probe shaft and lead out to where a signal can get to it easier.
    Yeah, I wasn't too concerned about the underwater aspect of your project as I was thinking if you were using an iphone you were willing to stick something down into the water while the iphone was safe and dry. So sure, you'd have to hack these things a bit such that the antenna is above water level.
    There are things used in plumbing where they send a video cam through a pipe to look for a leak or clog. Just found this one on ebay: http://www.ebay.com/itm/15M-SEWER-PI...item3a763bbf39
    So then get yourself a netbook and you're set.
    Here's one with a built in monitor:
    Barry
  • UncleMatt
    Yes, you could use a dedicated display such as in your link, but again that adds weight of separate display and its batteries. I was hoping to find a way to make use of the high def screen I am already carrying on my smart phone. I did find this page, which appears to show how to accomplish this task:
    I have some reading to do...
  • Altra
    Although, not as fun as inventing one.
  • Vortxrex
    You could skip the phone & just make a dedicated HD display. Underwater you can really see gold well as long as the water is clear. What kind of output does the HD camera use? HDMI or 3 composite?. I have quite a bit of experience gold dredging & you can usually see where the biggest pieces of gold are coming from (lots of times it is on top of a clay layer & not on bedrock).
    I think if you are in an area where nuggets are found, and the right types of bedrock are exposed you could make some nice finds
  • UncleMatt
    Well, I was hoping for more interest on this, but will post any progress I make in the future. Hope some here develop an interest in this. An app based on this concept would sell like hotcakes! Not just prospectors would use it either, it has many uses in many fields.
  • UncleMatt
  • UncleMatt
    Came across this in a search:
    I'm surprised the USB microscope guys don't seem to be targeting direct cellphone apps yet.
    You also could buy the iphone quadcopter and use the camera temporarily for your purpose...
    Something called "Cheese" may run usb cams on Linux. Think Rasberry PI I guess....
    Or use a netbook.
    Barry
    I was surprised as well. I will check out your leads on this. Note, iphone for quad copter is not submersible as far as I know. Also, a tablet defeats the purpose of keeping things as small and light as possible. My phone has a high def display that is all I need.
    On a tangent, I have often considered using a quadcopter to scan cliffsides for vein outcroppings...
  • bklein
    Or use a netbook.
    Barry
