Where to buy CZ coil connectors?
  • Where to buy CZ coil connectors?
    Looking to buy (possibly cheap) source of Fisher 5-pin CZ3d coil connectors.
    Any experience, idea, suggestion?
    Example how it look out:
    Contact 1st Texas Electronics http://www.fisherlab.com/industrial/links.htm
      WM6 I actually ordered a set for my CZ6 today as it uses the older style 4 pin. You can get the replacements at Mouser Electronics... SL405MX is the part number for the male connector on the end of the coil cable and SL175FX is the female connector that goes on the back of the housing. Hope this helps.
        change over both male and female connectors on 'aviation' 'microphone' 'minelab' 'etc'
        type like this https://www.ebay.com/itm/M16-2-3-4-5...BMlq4wF0Ho2pPg
          sorry Homefire at our continent is different global source https://www.distrelec.com/global/
          1st Texas Electronics is somewhere too afar... overseas.
          you write 'do not send overseas' and that means you do not want to send in EU.
            Thanks to all for your proposal.
            Yes, treasurehunter747, seem that SL405MX will be correct one. Thank you.
            KT315 both (male and female) connector replacement is possible solution,
            but does not suit well to me, cause I already have two flawless CZ coils.
            Need cable connectors for experimental build of (at least) one smaller coil.
              ok. that seems you are enemy of your purse.
              ill be keeping this topic on control and ask you after 3 weeks about the price you paid.
                Agree. Prices for SL405MX connectors are crazy, somewhere even $60 including shipping.
                I have two equal 1.5" coils and seem the cheapest solution could be, to sacrifice one
                of such male connectors, to build, together with cheap 5-pin Chinese female microphone
                connector, suitable adapter for all possible experimental coils. I already have a lot 5-pin
                microphone (cheap Chinese) connectors, so no additional cost and no need for surgical
                intervention on original box in this case. Thanks for all suggestion.
                This way:
                  SL405MX connectors- $9.68 USD
                    we can not buy from US continental just the shipping price is too expensive for us.
                    for an example
                      SL405MX connectors- $9.68 USD ("at Mouser")
                      Yes.
                      But I wish to buy 5 PCS of SL405MX.
                      With Mouser I got total (including shipping from EU dispatcher) of about $81.00.
                      A little to much for 5 connectors.
                      Total for 1PCS is $35.00 including shipping. Not happy too.
                      So I decided for coil connector adapter and use of way cheapest
                      and still solid Chinese parts which already have on stock.
