cheap interchangeable search coil
  • cheap interchangeable search coil
    greetings!!!
    search coil vacuum forming from scratch (vacuum forming plastic=empty 20 liters oil plastic container and a old CB Radio microphone connector for interchangeable search coil)
    regards!!!
    ikumi5
    Hi ikumi5,
    I think you're using too much metal near the coil (steel nut and bolt, too close aluminium rod and even connector have too much metal on it) and I think that you should to consider this a little more.
    Regards Marko.
      hello wallker,
      fine tuning knob will do the calibration (Discriminating the permanent metal near the search coil)
      thanks for your concern
      regards!!!
      ikumi5
        Wouldnt get away with that with a IB coil because you automaticaly would alter the inductance of at least one coil, hence balance ballsd up.
        However, once made a badly nulled coil into quite a go getter by adding a 3/8th steel bolt at 45 degree angle ofF the RX coil, so it not all doom and glume, learned that Idea from a old timer, everyday is a school day.
          it's a PI not an IB
          regards!!!
          ikumi5
